New engine stalling, hard starting
Old Jun 16, 2013 | 05:08 PM
richw40's Avatar
Car: Silverado 1986 TransAm
car is a 1986 trans am with a fresh 1973 Chevy 350- bored 0.30 over, mild cam, with a Edelbrock torker 2 and a rebuilt edelbrock 1406. I am using the mechanical fuel pump with 2 fuel filters car will not start up right, I need to put my foot to the floor to get it started then it wont idle unless I use the gas pedal and keep it at 800 rpm. I let my foot off the gas, and it dies. wont restart unless I do the same as above.
the car has headers with h-pipe exhaust, no mufflers on it yet.
when engine is running, oil pressure is 60-80 lbs.
timing is right on
run time so far is about 5 minutes
the carb was rebuilt by a reputable builder off eBay.
Im kind of stumped, would the carb and intake be a match , like just using a gasket between the two, or should there be a spacer? it is an open plenum.
Im leaning towards a carb problem, or setup.
any help would really be appreciated......Thanks !
Old Jun 18, 2013 | 03:13 PM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
Re: New engine stalling, hard starting
I would start looking for a vacuum leak of somekind.
The gasket problem can be checked by spraying around base of carb with with carb cleaner or starting fluid. If it speeds the idle up that is one of your problems.
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
