91 Z28 wouldn't start
Old Jun 18, 2013 | 02:14 PM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
I have looked high and low for a fix for these cars not starting and found this on my car after I replaced the starter,wrapped the starter.replaced the igniton switch,bypassed the vats with the resistor and Newrockies box,double checked the nuetral safety switch. etc.etc.
I found a clicking noise coming from my left kick panel under dash & started chasing wires and found A RELAY. Took off the kick panel & found a Anti Theft Starter Relay part # 14093107 AC DELCO an $ 18.00 part and replaced it & now car runs perfect. Starts each time.
I'm not saying this is your problem.
SEE THREAD LINKS BELOW
Old Jun 18, 2013 | 06:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 91 Z28 won't start "FIX"
The starter enable relay is well documented on here as the 1st thing to check with a no - crank problem ; especially on VATS equipped cars
https://www.thirdgen.org/forums/tpi/...ay-bypass.html
https://www.thirdgen.org/forums/elec...mp-bypass.html
https://www.thirdgen.org/forums/post...56-post14.html
https://www.thirdgen.org/forums/post...303-post6.html
Old Jun 19, 2013 | 09:28 AM
Tx 91Z28's Avatar
Engine: 350/350/350
Thanks for the links sir Vetteoz!
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
