Car wont start, no crank
Old Jun 18, 2013 | 02:31 PM
orangek's Avatar
Today leaving school I went to my car and i tried to start it and it wouldn't. I heard the fuel pump prime the engine, but when i turned the key to start it, I didn't hear a click, and it didn't even crank. 20 minutes later I went back to try and jump start it and it started right up without having to do anything. Any idea of what could be wrong, or what to look for?
Old Jun 18, 2013 | 02:33 PM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
Re: Car wont start, no crank
LLOK here I just posted it / https://www.thirdgen.org/forums/tech...ont-start.html
Old Jun 18, 2013 | 02:49 PM
orangek's Avatar
Originally Posted by Tx 91Z28
I'll check it out, thanks
Old Jun 18, 2013 | 06:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Any idea of what could be wrong?
Any IDEA what year car with what engine we are talking about here ????
Many differences across the years
Maybe if you filled in your profile we wouldn't have to guess ................
Old Jun 18, 2013 | 07:06 PM
orangek's Avatar
91 Z28, 5.7L auto
Old Jun 18, 2013 | 07:50 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
20 minutes later I went back and it started right up without having to do anything.
Heard of VATS ?
Start reading
https://www.thirdgen.org/vats_passkey_system
If the pellet on your key is worn/dirty or the contacts in the Ign barrel that read the pellet are dirty / worn then what you got will happen.
Have to wait 5 min between tries for the system to reset
Every time you turn the key to the start position ,the timer resets to zero again
Carry a spare key to try when it happens ; you do have a spare key don't you ????? because if you don't you could be permanently stranded somewhere
Old Jun 18, 2013 | 08:30 PM
orangek's Avatar
Heard of VATS ?
Start reading
The ignition was replaced about 3 months ago, mechanic lost they key, so he put a new ignition in, and I had a new VATS key for it.
bryan623
Mar 22, 2021 06:43 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
92projectcamaro
Aug 6, 2015 01:20 PM
