TPI lower plenum
Old Jun 18, 2013 | 05:32 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
TPI lower plenum
Does anyone know if the TPI base for an 86 and a 89 are the same. Mind you I know the intake bolt holes are at a different angle, but that is what I want. I located a nice set of heads but they are 87-95. I want to change the TPI base and switch everything else over.
Old Jun 18, 2013 | 05:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI lower plenum
Im not sure what you mean bye lower plenum. But the only difference in the intake in f-body between 86 and a 89 intake would be the inner 4 bolt angle but the holes can be elongated. The 89 intake does not have a provision for the ninth injector cold start timer switch.
Old Jun 18, 2013 | 06:37 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Ah ok. I wanted to make sure there were no other differences between the bases. What I want to do is use a newer base for the tpi so I can use newer heads.
Old Jun 18, 2013 | 06:39 PM
Engine: Lb9
Transmission: M20
http://www.hotrodlane.cc/Streetstories/choosetpi1.htm
Old Jun 18, 2013 | 07:22 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Thanks for all the info man. I am assuming that if I use a TPI base from later than 88 there is no cold start injector and I would have to make changes to the ecm.
Old Jun 18, 2013 | 08:12 PM
Engine: Lb9
Transmission: M20
you can drill and tap the plenum for the timer switch, or got to 89 $6E programing and buy a csi delete kit just to make sure the csi isn't leaking.
http://www.ebay.com/itm/Chevy-TPI-SBC-Cold-Start-9th-Injector-Block-Off-Delete-Kit-/380661635968?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a1339b80&vxp=mtr
Old Jun 18, 2013 | 08:30 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hey thanks for the fast responses. What I ended up doing was finding a decent priced TPI base for an 88 camaro with cold start injector. Didn't want to mess with compatibility. But this information is still very useful should I ever decide to delete the injector. Thank you so much!
Old Jun 18, 2013 | 08:51 PM
Engine: Lb9
Transmission: M20
If you do decide to go to the 89 programing lmk I offer reprograming service.
Old Jun 18, 2013 | 09:03 PM
Engine: Lb9
Transmission: M20
Delete !
MantyZ28
16
Dec 21, 2015 11:02 AM
NBrehm
Aug 25, 2015 11:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
