1983 z28 tbi c/f injection
Old Jun 28, 2013 | 09:51 PM
loujon's Avatar
rebuild dist. set #1 cylinder at tdc and using a breaker bar set timing to 0 degrees. engine cranks and runs almost perfectly for about 10 seconds and dies. getting code 42, however I disconnected the est bypass which is probably why i'm getting code 42. can anyone help me diagnose my problem? is the ignition control module or electronic spark control module the problem? note: when I connect it to the battery charger and select 225 amp engine start the engine cranks and idles good. please help. hope I did not give too much info.
Old Jun 28, 2013 | 10:10 PM
82tarecaro's Avatar
Re: 1983 z28 tbi c/f injection
Timing should be set to 6 degrees, although it should still run. How is your fuel pressure? Why did you rebuild the distributor? What problems were you having with the car? Will the car stay running if you give it gas?
If you put a battery charger on it the car will run fine? How is your alternator?
Old Jun 28, 2013 | 10:13 PM
82tarecaro's Avatar
Sorry I hit you with so many questions - just trying to get an idea why you are having issues with it. Code 42 is definitely from the bypass.
Cleotiz
Jan 6, 2018 08:56 PM
toronto formula
Nov 10, 2015 06:17 AM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
3tas4me
Sep 4, 2015 01:45 PM
