random misfire and cylinder 1 and 4 misfire codes.
Old Jun 30, 2013 | 08:53 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
I have replaced both rotor, cap and wires and the plugs roughly 2,500 miles ago. I might possibly have an intake leak could that cause a misfire? when he ran it there was three codes for a random misfire, cylinder 1 and 4 misfire codes. Im stumped on this one and I am out of ideas. Could it be my timing? or Ignition module?
Old Jun 30, 2013 | 09:12 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: random misfire and cylinder 1 and 4 misfire codes.
how was a code ran that pinpointed cylinder misfire? unless u have late model electronics thats kinda hard.
Old Jun 30, 2013 | 09:31 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
The guy at orileys ran it with his old code reader
Old Jun 30, 2013 | 10:00 PM
Car: 91 formula ws6
Transmission: 4l60E
What I'm trying to say is that Ur computer can not pinpoint what cylinder is misfiring. Your info says 84 6 banger. Computers weren't advanced enough back then to give a fairly accurate misfire code. They were generic. I've noticed u have made a few threads today about Ur issue. Now, down to diagnostics. Why do u feel 1&4 are misfiring? Is it carbed, tbi , or mpfi? Have u kept up on maintenance? One of your other threads says u just did a tune up with no wires? Why? Seems strange to go after intake gaskets for a misfire without hearing why.
Old Jul 1, 2013 | 02:28 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Its carbed, and I put new wires in yesterday and it is still misfiring but its only a slight misfire. I think my timing is off, but im nit sure how to reset the timing.
Old Jul 1, 2013 | 05:56 PM
Car: 91 formula ws6
Transmission: 4l60E
check that first. that can cause a minor misfire. hows the carb looking? cruddy or nice a clean with no leaks? have u sprayed carb cleaner around the intake area? check for vacuum leaks. what u may have is a lean misfire.
im not sure on the v6 timing. i never had to adjust one. it may be in the tech articles.
Old Jul 2, 2013 | 02:10 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
The carb is not leaking, and I have been spraying carb cleaner to clean it out and around to find a leak, so far I have only found one but alot of my vacuum lines look like they need replacing so I am going to go through and fix alot of the vacuum lines, the strange thing is that I drove it all day perfectly fine and then let it sit for an hour and then it started misfiring out of nowhere which leads me to assume that it isnt timing and that a vacuum line busted thus creating a misfire out of nowhere.
Old Jul 2, 2013 | 03:33 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The DTCs you're talking about would be P0300"random/multiple misfire", P0301"misfire cyl 1", and P0304"misfire cyl 4". As stated, these codes only apply to 1995 and later vehicles with OBDII compliant engine management. I really wish that boneheads at auto parts stores would just stop scanning peoples cars and misleading them.
Old Jul 2, 2013 | 03:47 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Are you sure of which cylinders are misfiring? A power balance test will point them out. Pinpointing which cylinders are misfiring is the generally the first step in determining what's causing the problem. Plug wire routing is critical on these cars. Be sure that no wires have been damaged from contact with the exhaust manifolds.
Old Jul 2, 2013 | 07:36 PM
Car: 91 formula ws6
Transmission: 4l60E
I once had a handheld scanner. Then I bought my MODIS. Lol. Fix the lines op and see if that helps.
Old Jul 2, 2013 | 07:59 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
I put all new wires, rotar and cap. But today I looked under my vehicle and seen there was a plug wire hanging down but when I checked the engine all of the plugs were still in so I will prop it up here soon and see where that wire is hanging from
Old Jul 3, 2013 | 02:58 AM
Billyjoebob007's Avatar
Car: 83 Camaro Z28 (CFI)
Engine: 305 V8 (CFI)
My 97 JeeP zj for the past year has been throwing those same misfire codes. Dunno whats the cause of it. When the engine light comes on i detect no change in the engine associated with those codes like dieseling/pinging/etc etc. I know my plenum (intake manifold) is leaking due to oil consumption and oil in there under the throttle body. Perhaps that is the cause of the codes, i dunno .
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
NZKnight
Oct 15, 2015 02:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
