Help with removing and IDing some Emissions stuff.
Old Jul 16, 2013 | 09:34 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I removed most of the Emissions stuff from my Car after switching over to Non Comp controlled carb and dist.
What can I do about the charcoal canister? there is also something in front of it that has vacuum and a bracket I think it is for Cruise control which I don't use or need either. Then in the lower fender area there is a Round thing with vacuum,
Can all of these be removed?
What are they for?
What do I do with the vac hoses?
Old Jul 16, 2013 | 09:37 AM
Twin_Turbo's Avatar
Re: Help with removing and IDing some Emissions stuff.
the vac servo is for cruise yes. You need to cap off the line where it's Ted from the vac line to the hvac controls.
the round thing is the vac resrvoir. Kind of handy to keep
without the charcoal canister it's gonna reek of fuel.
Old Jul 16, 2013 | 11:15 AM
BLACK Z's Avatar
Car: 86 Z28
SO, The box next to the radiator that has mounting bracket and used to have a cable running to it is just for the cruise control? Is that the only one you recommend removing?
Old Jul 16, 2013 | 05:58 PM
Twin_Turbo's Avatar
Yes, this is the cruise servo
Old Jul 16, 2013 | 07:38 PM
BLACK Z's Avatar
Car: 86 Z28
SO I can remove that with out any issues then? I don't use it, I have owned the car for 20 YEars and I don't think it has ever worked.
Old Jul 16, 2013 | 07:41 PM
Twin_Turbo's Avatar
yup
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
