Need help identifying these parts.
Old Jul 16, 2013 | 02:42 PM
BadRiggins's Avatar
Car: 1989 Pontiac Firebird Trans Am
Engine: 5.0 305 V8 FI
Transmission: 700R4 Automatic
I need/want to know what these two parts are...
One is on the passanger side and the other is on the drivers side.
Thanks.
Attached Thumbnails Need help identifying these parts.-2013-07-16_15.21.17.jpg   Need help identifying these parts.-2013-07-16_15.21.07.jpg
Old Jul 16, 2013 | 03:30 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Need help identifying these parts.
One on the left is your A.I.R control valve. The one on the right deals with your cruise control. 88 service manual should give you some more info. Or you can do a search through the forums.
https://www.thirdgen.org/forums/tech...ce-manual.html
Old Jul 16, 2013 | 08:40 PM
BadRiggins's Avatar
Do I need the control valve or is it one of those things that you can remove with a better experience or no change? Thanks.
Old Jul 16, 2013 | 10:50 PM
antares57's Avatar
From the 88 service manual:
Purpose: The A.I.R. system helps reduce hydrocarbon (HC), carbon monoxide (CO), and oxides of nitrogen (NO,) exhaust emissions. It also heats up the catalytic converter quickly on engine start-up so conversion of exhaust gases can occur sooner. A Dual bed converter is used. It consists of a three way catalyst (which controls all three emissions) in series with a two way catalyst (which controls only HC and CO) both are in one housing. A pipe between the two converters allows air to be injected into the second (two way) converter to increase its efficiency to further control HC and CO.
What it does: A Control Valve
Air flows from the pump through an ECM controlled valve (called a control valve) through check valves to either the exhaust ports or the converter.
If disconnected: If no air (oxygen) flow enters the exhaust stream at the exhaust ports, HC and CO emission levels will be too high. Air flowing to the exhaust ports at all times could increase temperature of the converter. Air flowing at all times to the catalytic converter may cause converter overheating during rich operation.
The A.I.R system on my 88 Firebird was removed by the previous owner. Hope this helps.
Old Jul 16, 2013 | 10:56 PM
BadRiggins's Avatar
So its basically the emissions system? And without it it could cause my cat. to overheat? And it doesn't add or take away power?
Old Jul 16, 2013 | 11:01 PM
antares57's Avatar
That's it in a nutshell.
Old Jul 16, 2013 | 11:04 PM
BadRiggins's Avatar
Alright, thank you. Oh, and do you know what size of injectors are in a 1989 trans am?
Old Jul 16, 2013 | 11:08 PM
antares57's Avatar
Sorry, do not off hand. Do a search for "1989 Trans Am injectors". Also if you want to get rid of the A.I.R. system, do a search on "A.I.R.". There are some folks that have removed theirs and says it runs better.
Ed1LE
Sep 30, 2018 09:14 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
6998poncho
Sep 25, 2015 02:56 PM
Linson
Sep 21, 2015 01:08 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
