Two piece RMS oil pan recommendation for third gen
Old Jul 20, 2013 | 04:20 PM
galletti's Avatar
Car: 1988 IROC Convertible
Hi all,
I finally bit the bullet to put a 350 in my '88 convertible because I found an old 39770014 short block fresh from the machine shop with like new internals for $150. My problem is I wanted to use my stock oil pan to save $$$ but then I realized mine is a one piece RMS. I got a nice chrome oil pan thrown in but it's for earlier cars and, as I understand it, will not fit in a thirdgen. I saw Summit racing has some Canton pans that'll fit and are 2 piece RMS but they are over $300. Any suggestion?
Old Jul 20, 2013 | 04:25 PM
Re: Two piece RMS oil pan recommendation for third gen
http://paceperformance.com/i-6536345...y-engines.html
Needs a windage tray; I usually use the Moroso Teflon-coated one.
Old Jul 20, 2013 | 04:32 PM
galletti's Avatar
Dude! That was fast From what I can tell, that means that any oil pan for an L82 vette will serve my purposes. Is that correct? It's just that the particular one you linked to is listed as discontinued. Thanks for the info!!!
Old Jul 20, 2013 | 05:19 PM
That would SUCK if it was discontinued.
I've been using that pan for about 3 decades now, in EVERYTHING (it fits ALL chassis).
Google the part # and see what you get.
Old Jul 20, 2013 | 05:26 PM
galletti's Avatar
Ok. I'll do that. I chatted online with one of their advisors and he said he'd get back to me.
Old Jul 22, 2013 | 07:39 AM
galletti's Avatar
So I checked several places and this particular pan is no longer available. However, I may have a new understanding on the fitment of the pan. I always understood that I couldn't use an older oil pan on a newer vehicle and I thought it was because of fitment. When I realized it was because of rear main seal design, I still kept thinking there was a fitment issue. Looking at various oil pans recently though, I believe they should fit ok. Any thoughts?
Old Jul 22, 2013 | 09:58 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Not sure what your doing with the car but I'm using a canton oilpan on my 2piece motor.
Old Jul 22, 2013 | 10:40 AM
galletti's Avatar
Thanks TTOP. Do you have a part number on that?
Old Jul 22, 2013 | 11:07 AM
TTOP350's Avatar
This is what I use.
https://www.cantonracingproducts.com...F-BODY-RR-PAN/
Make sure you purchase the proper pump pickup and plug 4 the oil level bung.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
