Functional Hood Scoop
Old Aug 2, 2013 | 04:19 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Does anyone know how the functional hood scoop works on a 1983 Trans Am
305 HO. It used to work, its not the motor and I have power to the motor. Is there some kinds vacuum that hooks up to that little thing behind the brake booster. Between the hood scoop and the windsheild washer eveything else works. Or does anyone have some HD pics of a stock 305 motor with
the original 4 barrel carb. I could really use it.
Al
Old Aug 8, 2013 | 05:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know details, because I've never had a Firebird, but I believe it is powered by vacuum and controlled electrically.
Since you hadn't received any responses, perhaps this will help stimulate a proper answer for you.
Old Aug 8, 2013 | 06:00 PM
Joe Tag's Avatar
Re: Functional Hood Scoop
I know the 81 camaro had an induction hood that had an electric actuator. Engine didn't have to even be running to trigger it, just ignition on. I don't see them taking a step back to go to 60s technology in 3rd gens.
Old Aug 12, 2013 | 10:58 AM
svrider76's Avatar
Car: '83 TA DT500 HT
Engine: LG4
Axle/Gears: G80, 373
Any update on this? My scoop is non-functional at the moment as well, I would like to make it functional so i can drive in the rain.
Old Aug 12, 2013 | 11:39 AM
svrider76's Avatar
Engine: LG4
https://www.thirdgen.org/forums/tech...ystery-me.html
So did some searching. There is the above part (vaccume relay) and there is a solenoid (electrical) on the scoop itself. How to reconnect everything together, I dont know. Will try to collect information here in one spot.
Old Aug 12, 2013 | 05:02 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Thanks, That's one part the other one I took off I will have to take a pic of it. It has a little nipple on the end of it. So maybe a vac hose goes from the part to the carb.
That's why my flap does not open. I still have the old rodchester and comp.control
in it.
Old Aug 12, 2013 | 05:13 PM
Jeffs82TA's Avatar
in it.
The solenoid always has ignition power. It is opened when zero vacuum is achieved through that vacuum switch. The switch itself makes a ground for the solenoid is all. It isn't computer controlled, and does not have power going through it. It's vacuum feed was off the carb IIRC, hope that helps.
Old Aug 12, 2013 | 06:19 PM
svrider76's Avatar
Engine: LG4
Okay here's what I got after checking out my system today. I have a chewed/broken wire and I dont know what all the parts of my system are. I put the engine back in the car about 1.5 years ago and who knows if i routed all the vaccume lines correctly.
But, I wonder what went on the drain holes on the bottom of the scoop (see picture). When i bought the car it had water on/in the air cleaner lid, Im assuming from the scoop being failed open.
Any thoughts here?
Attached Thumbnails Functional Hood Scoop-hoodscoopwiringedited.jpg   Functional Hood Scoop-hoodscoopwiring2.jpg   Functional Hood Scoop-hoodscoop1.jpg
Old Aug 13, 2013 | 09:02 AM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Yep that's it so were does the vacuum line go? I have power to the motor but I guess
I took the vacuum line off that little nipple.
Ak
Old Aug 13, 2013 | 09:04 AM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
I thought that was part of the windshield washer system, that does not work either.
Old Aug 13, 2013 | 11:56 AM
svrider76's Avatar
Engine: LG4
Ill take a picture of where i routed mine. Its T'ed in with two other lines that go to the black "canister" strange thing to the left that you can actually kind of see in the first picture.
That being said, i dont know if that is the correct routing as i pulled my engine a year ago and replaced a bunch of lines.
Also can you take a picture of your wire routing? it seems i have to re-wire mine.
Also does this fail open or closed?
Old Aug 13, 2013 | 06:25 PM
Jeffs82TA's Avatar
Any thoughts here?
Nothing went on the water drains
Old Aug 17, 2013 | 04:18 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Put the vacuum hose on the little nipple next to the relay still no functional hood scoop,
maybe I hooked it up wrong not sure we're it goes. I will check again later.
Al
Old Aug 17, 2013 | 07:51 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Maybe This Can Be Of Some Help.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
