help me please!
Old Aug 11, 2013 | 01:55 PM
789roby789's Avatar
Car: 1986 Camaro Sport Coupe
Transmission: 700-R4
help me please!
So my car was able to burn out with ease but now when I try pressing the brake and give it gas to get the tires spinning it just stays there the tires don't spin what could it be? I heard the Carb back fire too my Carb was rebuilt a few months ago do I need to adjust it? Any info will be appreciated
Old Aug 11, 2013 | 02:08 PM
Joe Tag's Avatar
Re: help me please!
It kills me to constantly see people using power braking and spinning the wheels as a litmus test for how well a car runs. Truth is, this does nothing but damage and wear your tires faster. I'm glad you have the extra time and money to waste replacing parts and tires.
Old Aug 11, 2013 | 02:14 PM
789roby789's Avatar
Re: help me please!
Youre pissed or what?
Old Aug 11, 2013 | 02:23 PM
Joe Tag's Avatar
Re: help me please!
Apologies for being a wise ****, but these are facts. Try to enjoy the car not abuse it.
Old Aug 11, 2013 | 04:17 PM
Schrade's Avatar
Re: help me please!
I'm kinda' confused too...
Burnout at a car show I can see. But to diagnose a problem?
WHat's it doing?
Old Aug 11, 2013 | 04:57 PM
789roby789's Avatar
Re: help me please!
When I accelerate and have my foot on the brake the tires don't spin and burn it used to do it before but I don't know what's going on I feel the rear kinda lift up and that's it it just revs
Old Aug 11, 2013 | 05:15 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Re: help me please!
Try to peel out without holding the brake and check to see if both rear wheels leave tire marks. If you only see one, your posi probably went out.
Old Aug 12, 2013 | 08:06 AM
JaBoT's Avatar
Re: help me please!
Check the timing. Also it could be the carb is the issue since that's the one thing that was touched since the car started feeling different.
WHat's it doing?
The burnout is not the diagnosis, it's the symptom. His car used to be able to do it and now it can't. So now we have a symptom that needs to be diagnosed. Why can't his car spin the tires anymore?
The carb was bad would be diagnosing the problem.
Old Aug 12, 2013 | 10:37 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: help me please!
It kills me I'm glad you have the extra time and money to waste replacing parts and tires.
I take it you must not race, because brakes and tires are the first parts to wear out & replace.
Granted I did get 12 years out my Nitto Drag Radials.
However my rear brakes pads still look good and the fronts I replaced 2 seasons ago.
But I have a line lock, so when I do a burnout the rear brakes are not engaged. This keeps the rear pads from wearing out prematurely or damaging the rotors since you are not trying to over-power the rear brakes while doing the burnout.. (and creating excessive heat) the front brakes are engaged just to hold the car still in the water box.
My guess is OPs rear brakes are binding or otherwise damaged. Drum brakes are especially prone to damage from excessive heat.
Old Aug 13, 2013 | 12:08 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help me please!
it just revs
So if the engine is revving up and the tires are not that only leaves the thing in the middle ; the Gearbox !
Old Aug 13, 2013 | 09:12 AM
FRMULA88's Avatar
Car: 1988 Formula
Re: help me please!
or the rear end...
or the rear brakes are bound..
Old Aug 13, 2013 | 10:21 AM
Joe Tag's Avatar
Re: help me please!
LMAO you must have back-peddaled real fast vetteoz, doesn't even show an edit. That's not the whole comment I saw in email. It was a little harsh, but the truth. Pretty much my thoughts all along but I was a little more diplomatic and refrained.
Old Aug 13, 2013 | 02:16 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: help me please!
At least he's not doing neutral drops.
Old Aug 13, 2013 | 05:56 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: help me please!
The diplomacy is diminishing with old age and younger members of a certain generation with no diagnostic skills.
I am going to start adding this rider I found on another site
"WARNING:
The above advise is based on actual experience or just plain common sense.
In the event said advise is determined to be incorrect you are entitled to a full refund of exactly what you paid for it."
Old Aug 18, 2013 | 10:18 PM
Joe Tag's Avatar
Re: help me please!
It's hard to hold back when you see it over and over. Afterall, sarcasm is the bodys natural defense against stupidity. I even snapped at him, but I did offer my thoughts on the problem in a pm and a public apology.
We do have to remember a few things.
1) We all started out young and uninformed. I know I blew up a couple engines beating on them in my youth. My punishment by my father was to rebuild them. Lesson learned, and a skillset as well.
2) No matter how smart we think we are, there's always someone who is smarter that can take us down a notch.
