Locked up???
Old Aug 15, 2013 | 09:19 PM
luckydog0_18's Avatar
Car: 1986 camaro iroc-z28
Locked up???
ok so We installed a new built 350 into a 86 camaro with a 700R4 .
It ran for 20 seconds and shut off just like it stalled,
Restarted ran for about another 20 seconds and shut off
now its locked up.
Can not turn the engine by hand, pulled valve covers off
push rods look good and valves seem to be fine. Spark plugs are out
Still cant turn the engine over forward or reverse.
drive shaft off and still nothing.
Heard no odd noises when it ran or shut off, It sounded normal.
the torque converter was the original one( was not new) car
and old engine(305) had 52,000 miles.)
Any suggestions??? thank you in advance.
Old Aug 16, 2013 | 11:25 AM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Re: Locked up???
Was the engine primed with oil before you started it?
Old Aug 16, 2013 | 12:38 PM
Re: Locked up???
yes it was
Old Aug 16, 2013 | 01:26 PM
Engine: SBC 350
Re: Locked up???
Unbolt the torque converter from the flywheel. If the motor still doesn't turn, you know it's something on the motor end.
Old Aug 16, 2013 | 09:24 PM
Re: Locked up???
cant turn it to get to all the bolts. but got it ready to pull the engine and trans to see whats up.
Old Aug 16, 2013 | 11:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Locked up???
Restarted ran for about another 20 seconds and shut off now its locked up..
What oil pressure were you showing when it was running?
Old Aug 18, 2013 | 09:42 AM
Re: Locked up???
not sure. once i started it i went to under the hood to kind of look over things.
and it only ran for about 20 seconds twice and just shut off like it stalled.
Old Aug 18, 2013 | 07:56 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Locked up???
not sure.
New engine Rule # 1
Always use a mechanical oil pressure gauge ( one you know is accurate ) under the hood and watch it religiously during the 1st engine run.
Old Aug 19, 2013 | 07:25 PM
Re: Locked up???
New engine Rule # 1
I hear ya. Ill be honest at first I thought the torque converter was screwed up causing the problem. but then i thought maybe the bearings were installed backwards so to speak. but whatever the case it will be done right this time.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
