58 mm throttle body ,killed engine
Old Aug 17, 2013 | 07:42 AM
pheonix 525's Avatar
Car: 1988 gta se
Engine: 5.0 tpi
Transmission: man
i have a 1988 gta zz4 350 crane 2032 cam rooler rockers 10.5 to 1 compression walbro fuel pump 50 psi fuel pressure with 22lb/hr injectors headers 3 inch exaust accel runners stock ported base plate ,6 deg base timing hyper tech stage 2 chip, put 58 mm tb on and lost tons of power any ideas ?
Old Aug 17, 2013 | 08:14 AM
Damon's Avatar
Re: 58 mm throttle body ,killed engine
TPS set incorrectly? I don't recall exactly, but I think the 88 still uses the touchy "external arm" TPS, which is easy to set wrong.
And an off-the-shelf chip is unlikely to give optimum results when you start changing things as significant as a cam.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
