Fuel line repair
Car: 1987 Z28 IROC
Engine: 6.2L
Fuel line repair
When I bought my car I found out that the previous owner cut the hatch floor to gain access to the fuel pump. All the lines had also been cut. The feed and return had been joined using rubber hose and clamps. Not sure if the hose is fuel injection hose or not.
If I use proper EFI rubber hose and good EFI clamps will this keep working in the long run? Everyone in town wants $300 for a sending unit so I thought I would try this.
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Fuel line repair
Well, it will work. For how long is another question and if it ruptures, since your floor has been cut, you will end up with an interior full of gasoline which is a bad situation. I'd see if I could find some replacement lines from a donor car somewhere and fix it right.
Car: 1987 Z28 IROC
Engine: 6.2L
What years/engine cars can I get a unit out of? Does it have to come from a V8 TPI car? What about a EFI V6 or TBI?
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Car: 1987 Z28 IROC
Engine: 6.2L
TPI or TBI shouldn't matter. They just need to match in size and what you need. I have no idea what cars had what in what years though. I'd try to find one similar to what you have though.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Any fuel injected thirdgen 85-92 uses the same fuel sending unit but the pump in tpi is higher pressure. iron duke, 2.8l, 3.1, tbi and tpi all the same senders.
Car: 1987 Z28 IROC
Engine: 6.2L
I think I will just bite the expensive bullet and buy a new one. Auto parts store can have one for me tomorrow after lunch. It is that or splice the cut lines with EFI hose. But I certainly don't want to worry about the lines or ever have to drop the tank for the rest of the time I own the car.
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
LOL ! the previous Owner severed those lines with his jigsaw when cutting his "access panel" pretty obvious.
you can jury rig with compression unions, or fix it the right way.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
