Post your engine pictures!
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Hi guys, so if you have read any of my previous posts you probably know that I am trying to plan an engine build, and right now I'm looking for some dress up inspiration. I have a basic idea of what parts I want to be on it and what I want it to look like. Since a 305 and a 350 have the same block, I plan on making my engine look as close to stock as possible, with a few pretty touches of my own. Go ahead and post yours up, and enjoy browsing through others' builds!
Here's mine right now, this was taken way back in June 2011.
L03 V8, all original, although I did repaint the air cleaner lid and did some cleaning up.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Post your engine pictures!
It's not a street engine but it is in my third gen
nothing fancy
something fancy in the works
a finished engine bay
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Here's mine minus the Air cleaner lid.
Car: 1984 Trans Am
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
I am in love with this thread post, keep on posting your engines!
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Sorry for late reply, thirdgen for some reason does not send me emails anymore about post. Heads are RFD (Race Flow Development), it is actually a 565. Was originally going to build a 572 but the rod ratio is better with a 565.
No have not run it at the track.
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Car: 87 iroc-z
Engine: 454
Transmission: th350
Car: 87 iroc-z
Engine: 454
Transmission: th350
here's a place that sells them. this is probably what i should have just done?
http://www.prosystemsracing.com/cata...92/5233103.htm
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
when it was built 5 years ago, my first full build, 30k+ miles latter still running strong with over 210 compression pressure
Posted wrong area
Same as above
Car: 83Z28 HO
Transmission: G Force 5 speed
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Alot of nice pictures in this thread!
This was pre-406
Pre- Miniram conversion
This was pre-406
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Just wanted to post a completed update pic:
Up and running making 308rwhp and 323rwtq
Car: 88 IROC Clone
Engine: 305 TBI
Now that is what I am talking about. That is what I want to do to mine. What is a ballpark figure on something like this?
I am talking about post 37.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Linson
Aug 21, 2015 02:12 PM
