Stiff gas pedal, blew coolant hose
Old Sep 28, 2013 | 01:17 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
This morning I went to drive my 86 trans am 305 tpi and the gas pedal was obviously extremely stiff, I was driving it around and the engine would rev up but the power wasn't getting sent to the wheels and then smoke started pouring out the hood, popped the hood open and the coolant line going from the throttle body to what I believe goes to the heater box cracked at a coupling. I fixed the hose and reset the throttle and the pedal feels like butter but it's still extremely sluggish, was driving fine last night, any ideas guys?
Old Sep 28, 2013 | 04:46 PM
TylerSteez's Avatar
Engine: 383 stroker
Re: Stiff gas pedal, blew coolant hose
Seems like the tranny is slipping too, wasn't doing any of this the other day, I knew the tranny was shifting rough but am doubtful it sh*t the bed over night
Old Sep 28, 2013 | 08:56 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
If you 'reset the throttle', you probably disturbed the tv cable setting in the process. If so, this will need to be fixed before you drive it any further, you are risking transmission damage.
Why was the throttle stiff, and what did you 'reset' to fix it
Old Sep 28, 2013 | 09:57 PM
TylerSteez's Avatar
Engine: 383 stroker
Meant to say adjusted the throttle cable, I seriously woke up the next morning and started driving to autozone to get sand paper and I noticed immediately my pedal was stiff. The night before it wasn't stiff at all but I did notice something didn't seem right.
Old Sep 28, 2013 | 11:14 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
If you breathe on them tv cable's the wrong way they mess up, that should be an easy fix just test and tune. about you overheating issue once a motor overheats it wont ever be the same and i'm serious.
Old Sep 28, 2013 | 11:26 PM
TylerSteez's Avatar
Engine: 383 stroker
I know I need a new tranny because ever since I drove it this morning it's been slipping so the problem won't be solved with the test and tune idea. My motor didn't overheat, a coupling in a coolant line cracked and blew causing the coolant to smoke all over the hot engine
Old Sep 28, 2013 | 11:36 PM
89rs454's Avatar
Car: 1989 SS
Well if your tranny slipping and coupling blew maybe that's a sign it was beat to hard?
Old Sep 28, 2013 | 11:48 PM
TylerSteez's Avatar
Engine: 383 stroker
Well it's got 160,000 miles so the slipping isn't surprising and I actually get told I baby my car too much
Old Sep 28, 2013 | 11:59 PM
89rs454's Avatar
Car: 1989 SS
No big deal, **** i get on my car on the weekends just to make sure everything running right. And if it's not it's bugs the **** out of me.
GTAman
Sep 21, 2015 09:57 AM
angel2794
Sep 8, 2015 06:22 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
johanlindgren
Aug 16, 2015 12:16 AM
