running rough and blowing smoke
Car: 1986 camaro iroc z
Axle/Gears: stock
ok i have afew trouble shoting post that turned out to be the coil. i had put a thing of fuel system treat ment and a bit of carb cleaner in the gas tank with it only having 3/4ths of a tank in it. i had taken the intake off and the fuel rail to clean the injectors then put them back on i dont know whats happening any help is apreciated.
