Fuel Injector Questions
Old Oct 11, 2013 | 07:57 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
I have a 1985 2.8L v6 camaro. And I am going to be doing the swap from the original injectors to the ford bronco 2/ranger injectors tomorrow. My first question is can and should I change the cold start injector, too? My second question is how do you remove the cold start injector do you just pull on it and it pops out or is there a special method?
Old Oct 12, 2013 | 02:51 PM
ex-x-fire's Avatar
Re: Fuel Injector Questions
I wouldn't worry about the cold start injector, it looks like it bolts on.
Old Oct 12, 2013 | 09:03 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
Cool thanks for the information. I just went to the junk yard today and got a couple of injectors from a ford ranger 1988 but I did not realize until I got home that they were the pintel type. So I went back to the junk yard and pulled apart four 2.9L engines. None of them had the disc type fuel injector. I am going to have a buy a set from the auto parts store.
Old Oct 13, 2013 | 09:03 AM
southbay08's Avatar
auto parts store is going to charge you an arm and a leg for injectors.
We have the bosch injectors non pintle. The price for the set is what you will probably pay for one new.
Let us know if we can help
Old Oct 14, 2013 | 06:36 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
Yah it looks like I am probably going to have to purchase them from the store or southbay. Can you give me a link to 6 disc 15lbs ford injectors for my 2.8L v6 engine?
Old Oct 14, 2013 | 06:45 PM
southbay08's Avatar
http://www.southbayfuelinjectors.com...ufactured.html
15lb Firebird 1985-1992 2.8 3.1 TPi
The add says that they are for a firebird, but these are the ones you will need.
Old Oct 15, 2013 | 10:30 AM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
I am just double checking but these are the disk type injector correct? The reason I am asking is that there are no pictures of the injector tips and there is no description that specifies this.
Old Oct 15, 2013 | 02:38 PM
southbay08's Avatar
Sorry, yes, the are bosch and they have 4 hole spray.
Old Oct 17, 2013 | 12:06 AM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
I purchased a set of the injectors. I will be putting them in my car this weekend and I will post my findings.
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
