cleaning intake manifold
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
hey guys I I have my intake manifold off my lb9 and I figured it was a good time to clean it. what is a good way? I heard everything from soaking it in soapy water to using oven cleaner
Re: cleaning intake manifold
There's plenty of way to do it effectively. Both of the ways you mentioned work fine. Don't use abrasive stuff on it like wire brushes, though. If you must use a wire brush, use a brass brush, not a steel one.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Oven cleaner works well as does any quality degreaser like simple green or super clean. I try to use biodegradable stuff since I don't want to hurt my yard.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Funny you should ask,I did mine today(bored)I used Spray on Goofoff and a Brass brush as was mentioned earlier.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I cleand mine with dawn dish soap while changing the intake manifold gasket. Spray painted it and the valve covers with high temp black. It came out great.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
