Surging Idle to shut off
Old Oct 13, 2013 | 08:00 AM
jmpowie's Avatar
Car: 91 canaro rs
Engine: 5.0
Transmission: 5 speed
I picked up a 91 RS 305 tbi in a trade. The car has sat for 10 years. The fuel tank was drained and fuel pump replaced just before I got it. I replaced the distributor (broke when changing cap) cap, wires, plugs, pvc, belt, fuel filter, temp sender on manfold. Cleaned the TBI the ICA seems to be working ok, EGA cleaned working ok. Checked for Vac leaks could not find any.
The car runs fine for 1-2min then it starts to surge and die. Hit the key and it starts right back up but will surge again in 30sec. The temp gauge on the dash does not move even when the fan comes on so I pulled the temp sender plug off and the surging went away but it gives me a 15, 23 codes. If the new temp sender is bad why would it give me a code after unplugging it?
I have been reading a ton of posts about the surging problem but I can not seem to fix it.
Old Dec 11, 2013 | 05:17 PM
IrishGreen's Avatar
Car: 91 Camaro RS
Engine: 5.0 L 305
Axle/Gears: Stock
Re: Surging Idle to shut off
Did you ever get your problem fixed? I have a similar issue. 91 TBI 305 with 48,000 miles. I have replaced every sensor on the car with new parts. Car still had a loping idle. I checked the fuel pressure and was reading only 5 psi. So I am currently having a new fuel pump installed. Hoping this fixes the problem.
Let me know what you found out.
Old Dec 16, 2013 | 04:50 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Touch Of The Irish
The ECM is telling you the sensor is disconnected VIA setting those codes.
Originally Posted by IrishGreen
Car still has a loping idle.
That’s usually due to one or more plugs not firing at idle.
That’s low but you didn’t mention a power problem, and that would be exhibiting itself with a fuel pressure problem.
Happy Racing!
First One To Spin Me Next Season •.•.•.•.•.•.•.• Well I Might Just Mirror Drive ‘em The Whole Race
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
