Crank pully tighten or replace?
Old Oct 26, 2013 | 10:18 PM
stickySC's Avatar
Car: 03 Gmc Sierra ,85 camaro, astro
Engine: 305,
Transmission: a4
got a 85 sportscoupe. I noticed a lot of runout/ wobble on the crankpully a few months back. after having issues with charging system recently. I noticed some daylight between the 1st groove"closest to front" and middle groove on my 3 groove pully. has anyone seen these 3 groove pullys that are pieced? like [2 + 1 an get the 3 groove] I tightened up some of the bolts, an lost the daylight, still got a little wobble, but haven't drove it since.
Old Oct 26, 2013 | 10:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Crank pully tighten or replace?
Originally Posted by stickySC
I tightened up some of the bolts, an lost the daylight, still got a little wobble, .
I would be removing the pulley to check it's cond and if it is straight
Old Oct 27, 2013 | 11:28 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
runout is pretty common with GM pulleys-quality is quite variable-sometimes the grooves run true but the flange will appear to wobble,often the grooves wobble as well.The crank and water pump pulleys of my car had runout,so I went to the junkyard and gathered a bunch of pulleys-checking them until I found ones that were perfectDo check that your pully is tight and seated properly against the damper though.BTW had the same situation with the heater blower"squirrel cage"-variable quality of that molded plastic part too-checked several till a perfect one was found...
Old Oct 27, 2013 | 05:18 PM
stickySC's Avatar
Engine: 305,
Transmission: a4
thanks for the replys. That's what I heard from a friend about the wobble.
But if its a 2pc assembly I could just tighten it down.. But if its tearing its self apart, 1pc. I need to remove. I the ones ive seen are the 1pc 3 groove. any one ever install a 2pc crank pully with 3 grooves on a stock oem SBC ? 2 groove pc, and a1 groove piece
Old Oct 27, 2013 | 10:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
All I've seen on 3rd gens were 1-piece.
But, I may not have seen them all.
Winchester1094
Aug 18, 2015 10:23 AM
TheJoeY88
Aug 13, 2015 06:51 PM
mizz0313
Aug 12, 2015 06:45 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
