car refuses to start!
Old Oct 28, 2013 | 03:05 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
So my car has been running really rich for a long time(probably ever since i bought it 7 months ago) I don't know though because i was kind of naive when it came to cars. it was also missing and had a bad hesitation. it also would randomly start surging but that only happened a few times. So basically last week it started to run like crap right after i filled it up with 87 pure gas from a empty tank. on my way home from the gas station it died several times and it refused to idle. Once i got home the car would idle but had a bad miss and the exhaust smell was very noticeable. So i took it to a friends house to get an opinion from his very knowledgeable father he told me it probably was one of the sensors. He had me hold the brake and try to take off. He said it was blowing black smoke and he told me to change out the sensors i had replaced. The following day i started it up and I looked at the tailpipe and liquid was literally being sprayed out the exhaust it appeared to be gasoline by smell. it was also smoking very bad. So I got the bright idea to try to reset the ecu. By the way I was checking for codes at this time using the paperclip method. I had reset the ecu when i changed the o2 sensor so basically no codes showed up. So i go out yesterday morning and re hook the positive battery cable and start it up. the car idles for a second then begins to bog down and miss and eventually dies. so I try to restart the engine and i t just turns over and wont fire so i continue to try. The best i get is a cylinder firing every few revolutions. So I get frustrated and conclude that i flooded it. The next morning i go to try to start it same thing. anyway i pull a spark plug and its completely black on the and wet. so i replace all of them with ac delco plugs while making sure to gap every single one. I try it still nothing. the best ive got it so far to start is have someone pushing on the gas pedal while i spray starting fluid in the throttle. Now i have a dilemma my battery is sparking every time i go to start the car from the positive terminal and gets super hot its not little sparks either im talking about touching two jumper cable together criss crossed sparks. The bolt that holds it on to the battery gets super heated and actually welded part of my amp wire onto the battery. now I am afraid to even mess with it Extra info:The car is a 91 v6 3.1l firebird auto trans. I have repalced the map sensor the IAT sensor and the o2 sensor in the last month. car ran considerably well before that.
Old Oct 28, 2013 | 07:10 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: car refuses to start!
How long has it been since this vehicle has had a real tune up?
Old Oct 28, 2013 | 11:57 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
idk but i replaced the plugs and wires like a month ago then replaced the spark plugs yesterday but probably never
Old Oct 28, 2013 | 03:19 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
please help guys
Old Oct 28, 2013 | 06:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by rfoster23g
please help guys
I suggest you do a full check of the spark system
http://easyautodiagnostics.com/gm_ic...n_module_1.php
then you can move on to the fuel
Old Oct 28, 2013 | 10:06 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
well i can for sure tell you that its getting spark becuase i shocked myself on the distributer and it did manage to start for a few seconds on starting fluid but i cant seem to replicate it
Old Oct 29, 2013 | 01:22 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You obviously know better .
A wet plug is a good indication that it is not firing correctly
Being able to see a spark on the outside and having a strong enough spark inside the cylinder to fire a wet plug are 2 different things
The fluid vaporizes and lights up easier that gas , that is why it is called " starting " fluid
Old Oct 29, 2013 | 09:21 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
ok well thanks i thought the plug was wet because i flooded it I will try to test the spark but i have a 3.1l v6 will the guide you linked still work
Old Oct 29, 2013 | 06:10 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Could well be but you gotta start testing one or the other ; fuel or spark .
Pick one
Old Oct 29, 2013 | 07:22 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
so i got it started and it idled for a while(like 1 min)after some revving then died. it smokes really bad and theirs smoke coming out from somewhere in the engine
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
