oil leak on exhaust
Old 11-06-2013, 11:52 AM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
oil leak on exhaust
Howdy,
I have an 85 t/a, 305 mostly stock minus an edelbrock intake and a 4 barrel.
Runs fine, but after a couple mins of running she smokes from either side of the engine and appears to be coming from the flanges on the exhaust manifolds. They are indeed wet with oil.
Could that be a leaky head gasket?
when I got the car, she was sitting for like 9 years. I've replaced intake gaskets, exhaust manifold gaskets, dizzy gasket and valve cover gaskets. Never pulled the heads so never replaced em.
The leak appears to start around the #8 and 7 bottom of the heads
Any ideas?
Old 11-06-2013, 12:22 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: oil leak on exhaust
I would guess valve cover gasket.
Old 11-06-2013, 12:37 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Or the back of the intake is leaking oil.
Old 11-06-2013, 01:05 PM
Chad85T/A's Avatar
Car: 85 T/A
If you over tightened the valve cover when you replaced the gasket you probably cut the gasket. I would pull the covers back off and check the gaskets.
Old 11-06-2013, 01:09 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
It could be an intake gasket but my money is on the valve cover gaskets.
Old 11-06-2013, 03:35 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I always use a torque wrench when tightening even the valve covers, can't remember exactly but think something like 7 foot lbs on the valve covers. This requires that I use my inch pound wrench and multiply by 12. Works great to keep you from over tightening the gaskets.
Old 11-06-2013, 04:47 PM
rockstarr4's Avatar
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
Another potential source of oil leakage from the back of the block area is a leaking oil sending unit (which is under full oil pressure all the time). BTW, it can still function when it leaks.
I recently fixed a persistent heavy leak from behind the block when I replaced my oil pressure sending unit at the time I installed new gages. It was an unexpected bonus that my oil leak went away!
xxx3man`
09-23-2015 10:37 PM
downsouthboy
08-29-2015 11:29 AM
TheExaminer
08-26-2015 04:59 PM
Navy8125
08-21-2015 09:32 AM
drathaar907
08-06-2015 04:20 PM
Quick Reply: oil leak on exhaust
