Windshield wipers not cleaning in the "middle" of the blade?
Old Nov 8, 2013 | 09:02 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey all,
Ever since I bought my 84 T/A, I'd have a problem with the Windshield wipers not cleaning the center of the blade area when they're on. I've tried different blades, and even different wiper arms. It gets really annoying because I always have this dirty streak of dirt/water where the blades didn't clean right in front of my face. If it was an edge it wouldn't matter so much but it's right in front of me.
Is there an adustment or something else I can look at to make the arms push down in the center of the blade area more?
Old Nov 8, 2013 | 10:02 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Windshield wipers not cleaning in the "middle" of the blad?
try new wiper blades and buy the good ones... not the cheap ones made in china
and don't use blade refills... buy new blades with the new brackets.
You can try to bend or straighten the wiper arms. The windshield is relatively "flat" so it may be the blades you are using are "bowed" and the arms arm not applying enough pressure to flatten the blade.
you can adjust the arm by just bending it towards the windshield. hard to explain by typing... but the arm should pivot from where it attaches to the cowl, so pivot it and then bend the arm towards the windshield... not to aggressive.. the arm is spring steel so it will not take much pressure to help contour it back into shape.
Old Nov 9, 2013 | 08:44 AM
HeathAU25's Avatar
Yeah I have the same problem. Cheap blades. Thought it might even be the windshield being cracked/warped since it was the original windshield, but then I had the glass replaced and the blades did the same thing. Going to try some Bosch or something next.
Old Dec 13, 2013 | 08:35 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I tried two sets of new blades. One bosh and one RainX and still the same problem. So I'm down $50 and it's still broke. GRRR! It's got to the the wiper arm or the geometry of it or something along those lines.
Old Feb 19, 2014 | 09:05 PM
99olo's Avatar
Car: 1982 Pontiac Trans-AM
Engine: 283
Transmission: Saginaw 4 Speed
Hey! What happened with this?
Old Jul 23, 2014 | 09:33 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I got the drivers side to clear with a new blade. However, the passenger side is another story.
I pulled the entire wiper arm free, re-seated it and put it back on. Worked well enough for about 3 weeks, and then started not cleaning the center of the window again.
So far I've tried 17" blade (1 inch shorter), the standard 18 inch bladed, and have reseated the arm on the pivot, all to no avail. Really kind of unhappy right now and not sure where to turn, unless the spring in the arm needs to be tightened some how. Maybe I got a bad wiper arm when I originally replaced it?
Old Jul 23, 2014 | 11:15 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Windshield wipers not cleaning in the "middle" of the blade?
Complete other side of the coin here!!
Driver side has so much tension // pressure that I get rubber streaks on the ends!! :-(
Pass side is good.
Old Jul 23, 2014 | 11:31 AM
Joe Tag's Avatar
Ozz, I've had this problem before and it was the tension, or lack of it. Dirt and corrosion at the hinging point of the arm. Try a little lube there and working the hinge back and forth. Possibly bending the flat part of the arm towards the windshield a little as formula88 suggested.
Old Jul 23, 2014 | 11:41 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I'll give it a try, kind of at the end of what I know might work to fix it.
Old Aug 11, 2020 | 06:53 PM
DoctorStoopid's Avatar
Car: 1987 Trans Am
Engine: LG4 305
Sorry to resurrect a dead thread, But I am having the EXACT same issue: My passenger side wiper does not make contact in the center, only on the edges, and I can't bend the arm in any way that makes a difference. Does anybody have a specific wiper blade they use to remedy this?
Old Aug 11, 2020 | 07:26 PM
OrangeBird's Avatar
Car: 1989 Firebird
I had the very same problem and ended up curing it with a new set of wiper arms and blades . The springs in my original wiper arms didn't feel all that weak to me , till I felt the tension of the new arms , Wow what a difference . This was some time ago when "Genuine AC Delco" parts were still somewhat better than the crap that comes with the AC Delco branding today , so I have no suggestion to offer on which brand name to choose .
Old Aug 11, 2020 | 08:34 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I always clean the outside on my windshield with Bon Ami, when I install new blades. Prepares the glass and cleans it well. Do NOT use any other brand of scouring powder!
Old Aug 12, 2020 | 11:44 AM
Car: 1987 Trans Am
Engine: LG4 305
I suppose it's possible the springs lose tension over time - can just the springs be replaced instead of a whole new arm?
Old Aug 12, 2020 | 02:07 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
I used to have this problem on my non-third gen. Switching to a one piece plastic beam type wiper instead of those janky old style multipiece wipers fixed it.
Attached Thumbnails Windshield wipers not cleaning in the "middle" of the blade?-windshield-wipers-3699-beam
Old Aug 13, 2020 | 07:57 AM
Vader's Avatar
I hope you don't plan on using those one-piece blades on anything you intend to drive in winter. I know Joplin gets a little snow now and then, but you'll be searching for some of those "janky old" blades if you get caught in any real winter weather, as long as they are not the plastic variety.
Old Aug 13, 2020 | 02:03 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
I've not yet had a problem. First time I tried that style of blade was putting them on my winter beater when I lived in VT. YMMV
Old Aug 15, 2020 | 08:06 AM
HeathAU25's Avatar
Hey! I'm one of the posters from the original thread. I ended up replacing both arms and blades and it's been perfect since. I didn't go all fancy with it or anything. Cant recall the brand but I usually just go middle grade for all car parts. The springs in the original arms had just become weak. Swap those out.
Old Aug 15, 2020 | 09:58 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Every car I've had since 2010 has has beam style blades and they've always far exceeded the performance of anything I've had previously.
Why do you consider beam blades bad for Winter? I have had no issues on 3 difference cars. I've found they wipe cleaner than the older styles arms.
Old Aug 15, 2020 | 10:30 AM
Car: 1987 Trans Am
Engine: LG4 305
I actually did end up replacing the blade with a traditional style blade and it worked a LITTLE better, but per what everybody else is saying, I'm gonna need to replace the arms eventually since the tension isn't there. I think those beam blades just have such a strong curvature to them that if the tension is already weak, the arm can't overcome the natural resistance of the blade's curve, whereas older type blades typically just lay flat anyway.
Old Dec 25, 2022 | 11:32 AM
winks46's Avatar
I would next check the wiper motor and gear assembly. If the assembly is loose or worn it may cause the wiper arm geometry or tension to change.
wigmobile
Feb 26, 2025 02:56 PM
Bohemian
Aug 15, 2017 05:11 PM
adelane
Sep 9, 2015 08:51 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
