Would like some help/info
Old Nov 16, 2013 | 07:36 PM
Uncle Howie's Avatar
Car: 84 Chevy Camaro Z28
Engine: 305 5.0L 150 HP
Transmission: 4 Speed Auto
I have a 84 z28 i'm having problems when I first start it. When I turn the key I get nothing just a faint sound of what I would say is juice from the battery. No clicking no nothing. I have to turn the key in the off postion then try to crank it again. I do this like 4 to 5 times before it turns over and starts.
Now the only thing I have tested was my battery so far and that was ok.
I was told it could be a number of things. ( starter, alternator and Ignition ) I would like to pin point the problem before I start replacing things that really isn't the problem.
Old Nov 16, 2013 | 07:42 PM
RaysUpRacing's Avatar
Car: 84 Camaro Berlinetta
Engine: 350 bored and stroked
Sounds like your Ignition is bad.
Old Nov 16, 2013 | 07:51 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I second this
Old Nov 16, 2013 | 08:40 PM
Re: Would like some help/info
When you say the "Ignition is bad" does that mean I need to replace the Ignition Coil or the Ignition switch ?
Old Nov 16, 2013 | 08:43 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
The switch
Old Nov 16, 2013 | 08:44 PM
Ignition switch
libolt
Jun 9, 2012 11:29 PM
crimsoncomedian
Mar 23, 2012 01:34 PM
J0hn_J0hn08
Carburetors
Jan 22, 2011 12:43 AM
Myfirst85
Jan 21, 2011 01:52 AM
F_N_JUNK
Jan 6, 2008 09:26 PM
