1986 IROC Problem
Old Nov 18, 2013 | 06:26 PM
dornewassj4's Avatar
Car: 1986 Chevrolet Camaro IROC-Z
Engine: 5.0 305 TPI
Transmission: Automatic
1986 IROC Problem
Bought a IROC that has been sitting a few years before I bought it because of a bad fuel pump. Had someone put new pump, sending unit, tank and purged the lines(My Brother). When I started using it, it had problems starting in the morning or when it sat for more then a day. Crank and crank until I gave it a shot of starting fluid and started right up. I figured ninth injector was bad. Without doing anything and using it more now it starts right up but idles high and the exhaust smells a little rich. When you let go of the brake it kinda wants to take off. Maybe ninth injector stuck open? Anyone have any other ideas I can check or how I can check it? Try to be a little easy on me. I know my way around a tool box and a motor but not too familiar with technical terms.
Old Nov 19, 2013 | 10:43 AM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: 1986 IROC Problem
If the fuel was left in the injectors when it was parked that is probable the issue. The injectors are probable sticking from the old fuel, try running a couple of bottles of injector cleaner through a half tank of gas, that should clear it up. The best thing would be to replace all of the injectors with some new ones from southbay fuel injectors.
Old Nov 19, 2013 | 05:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by dornewassj4
Anyone have any other ideas I can check or how I can check it? .
1st thing to do if you have any engine problems is pull the codes to see if the ECM is showing any problems with the engine sensors.
https://www.thirdgen.org/forums/tech...s-dumbies.html
Report back what you find
Old Nov 20, 2013 | 04:01 AM
Engine: 5.0 305 TPI
Should have mention that no check engine light and no trouble codes.
Steven 86IROC-Z
May 24, 2026 04:52 AM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
