Won't Start....?
Old Nov 25, 2013 | 09:42 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
Won't Start....?
First of all I have a 1991 camaro with the 3.1L v6. Yesterday I was letting it warm up to get some heat before I went out. When it was warming it up it just shut off. I went to go restart it and it would crank but not start. I checked to make sure the fuel pump was kicking on and it was. It's not out of gas because I had just fueled up. Any help or suggestions?
Old Nov 25, 2013 | 09:49 AM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Won't Start....?
Check to see whether you have spark coming out of the distributor. When my V6 3.1 did this it was my ignition control module. You can get it checked at Autozone. Do a search on icm. Good luck.
Old Nov 25, 2013 | 04:53 PM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
where is that located at?
Old Nov 25, 2013 | 11:36 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Inside the distributor under the rotor. Looks kinda like this
Old Nov 28, 2013 | 09:04 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
I replaced the ICM and noticed the rotor was cracked so i replaced the cap and rotor..... still no start. Any other ideas?
Old Nov 28, 2013 | 10:17 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If it tries to run with starter fluid or a little gas manually poured into the manifold, it's not an ignition issue. Try that.
Old Nov 28, 2013 | 11:50 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
starter fluid and gas didnt work....
Old Nov 28, 2013 | 11:53 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
its getting gas because when i crank it I can smell it....... its got to be spark then right?
Old Nov 28, 2013 | 07:17 PM
Have you checked for spark? Or did you skip that step and just start blindly replacing parts??
Old Nov 30, 2013 | 03:22 PM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
yeah I checked and I'm not getting spark even after replacing the ICM
Old Nov 30, 2013 | 03:26 PM
If you have spark, good, strong spark, and fuel then it should start. The 3.1L has multiport fuel injection right? Have you checked fuel pressure at the fuel rails?
Old Nov 30, 2013 | 03:33 PM
antares57's Avatar
Timing?
Old Nov 30, 2013 | 09:10 PM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
I checked and have no spark but how do you check the fuel rails?
Old Nov 30, 2013 | 09:42 PM
My mistake, I miss read your post about getting spark. If you don't have spark after changing the ICM check the coil & check the power to the coil.
Old Dec 1, 2013 | 11:47 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
It was the ignition coil...... thanks alot guys now I've had another problem as well.... when i start the car i have to keep a foot on the gas to keep the RPM's up or it dies. It does this for like the first 10 minutes of driving and then I dont have to do it anymore any suggestions?
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
