Trick Flow VS Edelbrock Head and cam packages, Which one?
Old Dec 7, 2013 | 08:12 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I am thinking of getting a Head and Cam Package from either Edelbrock or Trick FLow.
Which is the better kit? Out of the kits they offer which is the better package, How Many horse should I be looking for so the car is still street able and reliable.
The car is not a daily Driver less then 1,000 Miles a year but I still want it to be reliable for day to day use.
They both offer different levels of kits. Are they Complete, Should I have everything I need to make it work. Thanks
Old Dec 8, 2013 | 06:55 AM
Re: Trick Flow VS Edelbrock Head and cam packages, Which one?
Neither has a good cam. Not for any purpose other than taking your money.
Both have good heads. For different purposes; but "good" at least.
Pick the heads you want and get some other cam.
Old Dec 8, 2013 | 07:59 PM
BLACK Z's Avatar
Car: 86 Z28
WHat is wrong with the cam's? I like the idea of a Package, I guess I could put something together my self. Are either of the cams close to a Comp XE 268 Cam? Depending on the Package Lvl they have different cams in them.
Old Dec 8, 2013 | 08:18 PM
No.
Well,, ..... ,,, .. in all fairness, they do have the same # of lobes....
What are you thinking comes in a "package" besides the parts? If the parts aren't what you want, what good is the "package"?
Focus on the parts. If the "package" doesn't have good ones, then buy them some way other than a "package".
Old Dec 9, 2013 | 09:39 AM
JaBoT's Avatar
The rpm is just an outdated cam. Newer cams will make more power all around and have smother idle with more vacuum.
The 2 trickflow packages have either a tiny cam or a huge cam. Neither of which I would ever personally use.
If you like the comp xe268 look into a set of profiler 185cc heads. They really are by far the best bang for the buck and made in the USA.
http://www.profilerperformance.com/r.../sbc-23-degree
The dart shp heads are supposed to be pretty good and inexpensive, but I have personally never used them.
Get a performer rpm or airgap manifold and a holley style 650 dp carb and your set.
Old Dec 9, 2013 | 12:33 PM
BLACK Z's Avatar
Car: 86 Z28
My Buddy has a brand new Comp XE 274 he will sell to me for $ 75.
Well what would I need, I would like to order everything at once and have it ready to Go,
SO I would need,
Roller rockers 1.5? What kind?
Need Push Rods what size and brand?
Heads prob come with valves and Springs, Right Springs for cam?
Need Cam Which one? Lifters What ones?
Gaskets once again what ones?
Head Bolts what ones?
There are so many choices, figured a kit would be easier, How bad are the cams in there kits? Can I get just a head kit that has all of that stuff minus the cam and then I choose my own?
My Motor is a Low Comp GM 85 and earlier Replacement block.
What Size Intake Ports, What size chambers?
I just don't know what all to get and how to match it right.
I have a 650 Ultra DP on the car now along with a MSD Billet HEI.
Old Dec 10, 2013 | 06:56 PM
BLACK Z's Avatar
Car: 86 Z28
Are the Cam Specs that different between these two cams?
http://www.trickflow.com/partdetail....5&autoview=sku
http://www.compcams.com/Company/CC/c...x?csid=86&sb=2
Old Dec 10, 2013 | 07:29 PM
JaBoT's Avatar
SO I would need,
Roller rockers 1.5? What kind? 1.5
Need Push Rods what size and brand? head manufacturer will tell you
Heads prob come with valves and Springs, Right Springs for cam? Tell head manufacturer the cam size and they will get you the right springs.
Need Cam Which one? Lifters What ones? I like the lunati 60103 for you or a comp XE268H. Just buy the cam and lifter kit.
Gaskets once again what ones? The head manufacturer and or directions will tell you what gaskets to get
Head Bolts what ones? see previous answer
What Size Intake Ports, What size chambers? 185 - 195 ports and 64cc chambers
the carb and distributor should be fine.
Just call profiler. They will tell you everything you need. Its no more complicated than that.
Old Dec 11, 2013 | 08:54 PM
BLACK Z's Avatar
Car: 86 Z28
I guess push rods will have to be sized after motor is together. Trick FLow heads are 64 CC and 195 Ports.
What is the deal if I want to switch to a Roller cam? What do i need?
Is it worth it?
Old Dec 15, 2013 | 10:04 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I had a set of trick flow heads and was very happy with them. You can port them out without going to thin in important areas, unlike AFRs the valve seals aren't under oil, the valve cover perimeter is higher so you can use stock height valve covers. Mine were 195s but the profiler heads in 195 I think are cheaper and the same performance.
Old Dec 15, 2013 | 03:08 PM
BLACK Z's Avatar
Car: 86 Z28
Heads I am looking at are 195 and 64 Cambers, Online it says they are Angled Plug, when I called I was told they were straight. What were yours?
I have Straight now, I am not sure if Angled would work.
Old Dec 15, 2013 | 03:52 PM
Tibo's Avatar
Car: 1991 Z28 Vert
You really want angled or "L98 style" it will make working with spark plugs and large headers much easier. I had a set of world heads that were straight plugs and I had to run the accel "shorty style" plugs.
Old Dec 15, 2013 | 04:24 PM
1gary's Avatar
Neither take into account this and need to:
http://www.crankshaftcoalition.com/w..._compatibility
Old Dec 15, 2013 | 05:00 PM
BLACK Z's Avatar
Car: 86 Z28
So Angled is better in our cars?
I read though the Link I am still confused, WOuldnt 64 CC heads bump the compression to the low to mid 9's?
Old Dec 15, 2013 | 05:20 PM
1gary's Avatar
With those pistons and timing events matter for the cam/compression ratio AND the VOLUME with those pistons with the valve reliefs being what they are and finally the piston's being .025 in the hole all add up to being against you because of the quench.Then no knowing if Goodwrench is using standard re-builder pistons which has all the wrong piston pin height and if they do,that is a double negative towards any performance outcome.
http://www.crankshaftcoalition.com/wiki/Quench
Old Dec 15, 2013 | 05:26 PM
1gary's Avatar
I totally approve of the msg's in these links which are written better than I could.
84z96L31vortec
Aug 20, 2017 12:16 AM
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
