Leaking coolant rear engine?
Old Dec 22, 2013 | 10:56 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Been seeing light liquid almost water puddle out from unde car
It is not gas oil or tranny fluid
Unde the car it appears middle to rear of oil pan dripping down block and then also almost by rear seal and on tranny pan
Seems spread out but driver side if block and parts under neath all appear wet with water
I am thinking coolant it is not leaking a lot or overheating or smoking or bubbling and no watar in oil or oil in radiator
So is this head gasket? Minor leak or intake?
I am running lean at idle #2 looks lean and 6/8 are rich
Water neck on intake appears to be lacking a little too
Is this weeping after I shut off it seems can come from intake in rear?
I am thinking water neck and. Rear intake by 6-8 is weeping after I shut down?
Anyway to test or seal with rtv?
Old Dec 22, 2013 | 11:04 PM
Joe Tag's Avatar
Re: Leaking coolant rear engine?
Cooling system pressure tester. You can get one from auto zone on their loan a tool deal. Just a deposit you get back when you return it. Hooks up in place if the radiator cap, pump it up and get under and look where it comes from. I hope it's not a freeze plug. They're never fun.
Old Dec 23, 2013 | 12:06 AM
1gary's Avatar
You can also buy a dye kit that reacts to a blacklight.
Old Dec 23, 2013 | 08:09 AM
First: identify the substance.
Second: locate the source.
Third: repair it properly.
No, spooging something with RTV that's fully assembled, is unlikely to ever be successful.
No, running lean isn't a factor.
No, almost certainly not a head gasket.
If in fact it's coolant, most likely sources are the heater hose fitting on the intake, the intake gasket, or one of the core plugs. In that order of likelihood.
Water outlet needs fixed regardless.
Old Jan 10, 2014 | 12:00 AM
barryjoe's Avatar
If it looks like a block heater gone bad, remove it, patch it up and go from there. Head gaskets tend to fail internally at the cylinders where the stresses are greatest. Check your oil. If it's not a brown milkshake your probably right that it's the block heater. Warm and running the coolant is pressurized not only by the pump but by the expansion of the coolant. It will tend to blow like a whale and of course when it blows it lowers the pressure which lowers the boiling point of the coolant which leads to overheating pretty rapidly. You may want to consider replacing your water pump if it ran without coolant.
Old Jan 13, 2014 | 08:48 AM
jjcuff1's Avatar
Block heater = Freeze plug?
I am not seeing overheating but I think as you state a small leak after i shut the car off is expanding and leaking as it sits.
Old Jan 13, 2014 | 12:17 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Your not alone jjcuff1 my 87 iroc has a slow drip from back of motor. I think its a freeze plug but not sure yet. Gonna pull tranny when it gets warm and inspect back of block.
Old Jan 13, 2014 | 12:28 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
IG im not the only one!! my freeze plug went out to. the one right by the motor mount. but now i get a chance to change my springs and get some poly motor mounts
A freeze plug pops out when the coolant freezes, its more of a safety feature so the block wont crack.
Old Jan 13, 2014 | 12:36 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
I did all the freeze plugs in my 94 GMC (4.3) and the plug behind the motor mount I used the rubber adjustable one the, rest were standard brass replacements
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
