thoughts on this build / cam suggestion 406sbc
im helping a friend put together a cheap but nice 406 in a 70's iirc monte carlo for his dad as a present
he has a brand new unfinished 400 block , but i told him to sell it and just buy an finished shp block as there are no machine shops around here i would trust to finish the raw block
his dad will never drag race this , his dad used to own one when he was younger with a 400 so as a present he wants to build his dad one put it in the car he bought for him
the propsed build would be something to this extent
shp block machined .030 over for 406ci
forged roataing assembly with dished pistions aiming for 9.5-1
skip white aluminum 200cc cyl heads 64cc chambers
wieand stealth ram
long tube headers
megasquirt 2 controlling fuel and spark
not sure on trans or converter yet , so he hasnt picked out a cam just yet
more then likley it will be around a 2,500-2800 stall and th350 3:42-3:73 rear gear
can anyone suggest a cam for that setup?
yes i know on the heads already but they are cheap and like i said hes not looking to build a drag car here,but would like to see around 450hp
thoughts on what it would make power wise
cyl head flow int/ex
.100 70 / 55
.200 138 / 98
.300 188 / 138
.400 227 / 164
.500 244 / 181
.550 250 / 187
wieand stealth ram
long tube headers
.100 70 / 55
.200 138 / 98
.300 188 / 138
.400 227 / 164
.500 244 / 181
.550 250 / 187
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: thoughts on this build / cam suggestion 406sbc
You already know your answer, so why ask it? That build is mismatched and will not meet your expectations. Horsepower is irrelevant if it can't even be consistent in how and where it makes it in the power band (HEADS). I'd trust a stock 400 block before I'd ever buy cylinder heads from Skip White.
The import head that comes from ProHeader or Assualt Racing is a much better quality core. I have been through 3 pallets of them for a budget CNC head I offer. Never had a reported issue, and I'm sure I would.
Pictures of the core: http://www.1320techtalk.com/viewtopic.php?f=8&t=2256
im trying to talk him out of those heads , but i cant think of anything that that would be cheap to him that i would put on that engine. all my suggestions to him are alot more money lol
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
You could probably find a GOOD set of used heads that will fit your budget. I think you're doing things methodically which is great, but definitely keep your options open. I'd dig around for some used heads (for the kind of $ we're talking) to tie the budget up. I'd also up the compression to 10.5 or so; that way you've got more freedom on camshaft selection while offering the ability to create more power. A 406 will definitely shine with the right camshaft selection and lower compression is definitely limiting things.
our gas selection is limited here , 85/87/90 at just about all gas stations, 91/92 is very hard to get in our area
so to be on the safe side we have to give up a lil compression
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Dart shp's probably best bet for a shelf cheapy
Chris straub has some patriot based 185 heads for 750$ complete. Could try him at straubtechnologies.com
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Ah I see why you've decided to go that route. That makes sense now. I agree with your decision then. What kind of cam do you want to run?
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
If you have a Jeg's racers discount, buy a set of loaded Jeg's heads. They are Pro-Filer and have room to grow.
For $250 you can have a USA core.
Another option: http://www.pbmperformance.com/store.php?catId=794
also not a bad idea/price i will pass along the suggestions
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
It would be one thing if you opened them up some, but I think going with the Profilers would be a better alternative all things being equal. Not exactly the same price, but it's still "up there" so I don't see why you'de skimp when the price is negligible. For what you're doing it would foot the bill just fine I'd say.
Car: 89 Iroc-z
Transmission: TH400
Shp 180's are closer to 195 cc measured i believe, from a test from a head porter on another forum. They will support 450 hp on a 406 no problem
been talking to him some more , the raw block he has is a bowtie block he managed to find a reputable place in north utah to machine it so for the cost hes going to use the block he has, since it will be cheaper then the shp
only thing is he dont rember if it has 350 or 400 mains and if its a one or 2 piece seal , have to wait till thursday to go over and see exactly what he has
i did manage to talk him out of the cheap heads , now i just gota get him to sit down and think about exactly what he wants out of the engine
to be honest it prolly really wouldnt matter as his dad isnt really a car guy , and wouldnt know the difference between 300 and 500 hp, i bet u the engine whatever he decided on will never see past 1/2 throttle anyways
CarGuyDennis
137
Dec 6, 2016 11:02 PM
