My Camaro Dies
Old Dec 25, 2013 | 02:25 AM
Marcos123's Avatar
Car: 1992 camaro z28
My Camaro Dies
Okay so Iam trying to sell my car but a problem pop up. When Iam driving it for a while it dies with no warning sign it just turn off but it turn right up. Any sugection of what it can be please help.
Old Dec 26, 2013 | 10:51 PM
boricua24's Avatar
Re: My Camaro Dies
Well my camaro friend I hope someone can answer this question because I am having the same problem and I hear that it has something to do with egr valve so hopefully someone would help us out.
Old Dec 26, 2013 | 11:06 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
My 89' Rs did the same thing I never found the problem got rid of it after it was totaled
Old Dec 26, 2013 | 11:09 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: My Camaro Dies
lots of possibilities to cause that,but these caused the symptom with 3 cars I have:
-82 z28:bad connection to fuel pump relay(my fault)strangely,the loose connection kept setting code for MAP circuit,causing me to look there..
-69 Camaro:bad ignition switch.
-91 buick:bad ECM-never set codes,but swapped it out and problem was fixed.
Old Dec 26, 2013 | 11:38 PM
Marcos123's Avatar
Re: My Camaro Dies
I hope it's not the egr valve it was a pain to change it. I did change the fuel pump relay I am going to take a look at the ignition switch. Something else it dose is crank for a long time but only when I go to turn it on for the first time in the day. I don't know if that has anything to do with each other.
Old Dec 27, 2013 | 12:03 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: My Camaro Dies
Long cranking times can be caused by a faulty fuel pump relay, but because it is in parallel with the oil pump pressure switch the engine needs to crank long enough to raise the oil pressure high enough for the oil pressure switch to energize the fuel pump circuit.
Old Dec 27, 2013 | 12:30 PM
boricua24's Avatar
Re: My Camaro Dies
If my problem is any different when mine shuts off it's hard to turn back on even with the foot to the metal and when it does turn on alot of black smoke come out , I'm going to start by replacing the EGR valve and how hard can that be to replace any suggestions would help!
Old Dec 27, 2013 | 01:53 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: My Camaro Dies
You should never hold the pedal down all the way while starting. The ECM will think that you're trying to clear a flooded condition and shuts of the injectors.
Black smoke is a rich condition. injectors might be leaking, and or ECM coolant temp sensor is reading too cold. If the fuel pressure regulator diaphragm is ruptured fuel will be sucked into the manifold.
Have you checked for error codes?
I would not bother with the EGR until it has been tested there is a test procedure on this forum, you'll have to search for it.
Old Dec 27, 2013 | 10:17 PM
boricua24's Avatar
Re: My Camaro Dies
I'm sorry for the delay and thank you very much for the input, but when my ride shuts off in the middle of a red light that happens to turn green its kinda of a rush! Lol but yes the check engine light comes on at times and shuts off before I can even get to a mechanic and people tell me that when the check engine light shuts off for the most part it will clear the code. But again Iam gladly appreciate the help thank you!
Old Dec 28, 2013 | 12:48 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: My Camaro Dies
Most auto parts store can read the codes for free. I think that if when you get there just turn the ignition to the engine off/ key on position they'll be able to read the codes. I almost sure that the code is still in memory. Anyway it worth a try, won't cost you anything.
Old Dec 28, 2013 | 12:28 PM
boricua24's Avatar
Re: My Camaro Dies
Thanks for that info, I just got back fom a shop and they got a code 054 witch it says fuel pump relay so I'll replace that 1st and hopefully it would solve my problem, thanks again and I'll let u guys know good to go.
Old Jan 5, 2014 | 12:16 AM
Marcos123's Avatar
Re: My Camaro Dies
Well I tryed some of the things suggest but it did not work any more thinks I can look at. And boricua24 did the fuel pump relay fix the problem.
jklein337
Sep 19, 2018 06:23 PM
pimp2303
Jul 27, 2017 02:03 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
legendaryhero7
Aug 12, 2015 06:19 PM
