intermittent vibration please HELP!!!!!
Old Dec 31, 2013 | 03:14 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
So When I am driving at highway speeds [50- 65] the car will shake off and down at 50. The vibration kinda ebbs on until l the vibration gets so bad the dash board is literally shaking up and down like an inch then it starts smoothing out and starts it all over again. The vibration is not rpm related since I have a manual if i slip it into neutral it doesn't help at all. I do notice if I accelerate hard the car will shake so much its unbearable by 80 i must back off. i am going to go get a alignment tommorrow
Old Dec 31, 2013 | 06:53 AM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Re: intermittent vibration please HELP!!!!!
Sounds more like a driveshaft issue. out of phase, balance or bent, or bent axle.
Get rear off the ground, tack it up and have a look, see
Old Dec 31, 2013 | 10:26 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
do you think a alignment shop could help me spot it?
Old Jan 1, 2014 | 07:07 AM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Doubtful, you looking for bent or loose parts. Bad out of round tire, bent rim, would do it as well. If you don't work on your own stuff, your probably better off taking it to whoever does your work
Old Jan 1, 2014 | 11:43 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
its wierd though cus sometimes the car smoothes out ofr a minute but then after like 30 sec the vibration is back with a vengeance
Old Jan 1, 2014 | 12:14 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Here's a question.....
Do you feel it in the steering wheel or in the seat of your pants?
Steering wheel=front tires, ball joint or alignment
Seat of pants=rear tires, axle or drive line
Old Jan 2, 2014 | 01:47 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
The vibration is in the whole car but so i guess in the seat after it starts getting bad i can feel it in the steering wheel a little bit but when it gets bad it feels like the car is almost bouncing up and don extremely fast
Old Mar 14, 2014 | 02:27 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
This is a bump slash update (sorry about such a long gap). So the Vibration definitely doesn't feel like it is coming from the front but from the rear. I got the driveshaft balanced at a reputable driveline shop the clerk welded some weights on it and I think he said it was bent (not sure if he did so don't quote me). Though It didn't seem to help at all it actually feels worse hard to say though but it is definitely different. the car previously would be fine but as soon as you hit 65 it was like hitting a light switch but now I can feel it start ebbing on as soon as i hit 45 I took it up to 55 and it was getting worse I am scared to take it past there so I just took it home and parked it I was kinda bummed out. I have a v6 firebird that is as smooth as silk I have taken that thing up t 95 and it was good so I swapped the rear tires on to the camaro and it still does the same thing. So I am not sure what to do are there any more tests i can do any help would be appreciated
Old Mar 14, 2014 | 02:42 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Sounds like you have a (to quote from my old Jeep XJ days) "death wobble."
First thing to do is check and make sure your rims haven't thrown any weights, if they have, or you don't know, then get them balanced.
Second thing to do is to replace all of your bushings front and rear (or just any that haven't been replaced already). ESPECIALLY in the control arms.
This is a very common problem on Jeep Cherokee XJ's, the factory bushings wear out and then at various speeds, and intermittently, the thing with very well shake you off the road. Happened on mine, after having the tires balanced MULTIPLE times, replaced all the bushings and it drove like a Cadillac.
You're probably thinking "but I have a camaro...?" Well the only reason I say this is because the symptoms you described are exactly the same.
Hope that helps.
Old Mar 14, 2014 | 02:50 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
I am not opposed to replacing all the bushings but it does the shake for like 10 sec then goes away then starts back between 10-30 sec. I will definitely try that thanks man
Old Mar 15, 2014 | 09:54 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
would rotating the drive shaft help at all
Old Mar 16, 2014 | 11:12 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
bump
Old Mar 17, 2014 | 07:25 AM
Car: 1983 Z28
Yeah, that sounds about right honestly.
If the shop balanced it then rotating it wouldn't do anything (it's still just going to be spinning the same way, ya know?)
You could go to a junkyard and see if you can find a 4th gen driveshaft, they're aluminum, might help.
Old Mar 17, 2014 | 12:35 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
alright will do man but I think there is another vibration also when I am in park it really seems to shake the worse at 2000 rpm to 3000 rpm. I went to a transmission shop and the guy test drove it and he pointed it out. I am sure this is a factor but not sure how much
Old Mar 17, 2014 | 12:46 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
The stock driveshaft is NFG for high-performance use, it is not balanced.
Old Mar 17, 2014 | 01:08 PM
Car: 1983 Z28
What did he say about it? Have you checked your motor and transmission mounts? Past that I'm not sure what could cause extreme vibration while parked.
Old Mar 17, 2014 | 08:51 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
He said he thought that it could be the flywheel but he didn't know. No I haven't checked them but I will check them
Old Mar 18, 2014 | 07:06 AM
Car: 1983 Z28
Ok, yeah that could be it (since flywheels are balanced and all and anything balance can become unbalanced). Keep us posted
Old Mar 18, 2014 | 09:22 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Alright I will go ahead and replace all the bushings first and then see what is up with the flywheel
Old Mar 26, 2014 | 10:37 AM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Do you still have the driveline vibrations? Do you have discs or drum brakes? My drums were causing a similar issue at higher speeds because they were out of balance. It appeared that some of the original drum weights fell off.
Old Mar 26, 2014 | 12:10 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
You might be on to something there. When I swapped the tires from my firebird to my camaro I noticed that the firebird has 2 weights on each side where as the camaro has one weight on the drivers side drum. I am going to do a disc brake swap so I will see if that helps
Old Apr 10, 2014 | 12:57 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
In the next two weeks i hope to go pick up a 3.73 with posi from a 4th gen hopefully this is the answer.
Grant2k
Apr 4, 2016 08:21 AM
Reid Fleming
Oct 10, 2015 09:56 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
