Key buzzer stuck on
Old Dec 31, 2013 | 04:30 PM
dahn's Avatar
Car: 86 camaro
Transmission: 700 auto
Axle/Gears: 308
Key buzzer stuck on
I have a 86 camaro, I put in a ignition tumbler in, it starts now but my key warning buzzer is stuck on. The headlights and blinkers work ok and the headlights don't stay on like it's warning me of that.Can I just take out the warning switch that sit on top the hold down screw for the ignition cylinder? I don't really need it.THANKS
Old Dec 31, 2013 | 10:31 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
Re: Key buzzer stuck on
ya you certainly could but good luck when you live your lights on
Old Jan 2, 2014 | 07:15 PM
dahn's Avatar
Car: 86 camaro
Axle/Gears: 308
To install the lock tumbler correctly, you must turn the key to the run position install the warning switch,turn it back to the off position. That fixed the buzzer stuck on problem.
Gunner242
Dec 25, 2015 04:49 PM
tmellott89
Oct 14, 2015 02:06 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
