heat coming out floor vents when in off mode
Old Jan 1, 2014 | 10:41 PM
ht4100's Avatar
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
Ok this was last summer, I have an 86 Camaro with A/C. The heater, vent & defrost modes all work, the hot and cold modes seem to work also. When it is in "off" mode it hot air comes through the floor vents when the car is moving whether it is set to cold or hot, but it seems to be hotter if set to hot. If I set it to def, or ac or vent, no air will come through the heater.
Any ideas? annoying having hot air coming through heater on a warm summer day. I never remember this car doing that before, have owned for a long time.
Old Jan 6, 2014 | 05:31 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Diverter Converter
Sounds like the Heater Water Valve is not functioning.
It’s supposed to get vacuum when the HVAC control is set to
COLD.
See if it is.
The Heater Water Valve is located on the right side of the intake manifold, ruffly 2/3 near the front.
You should see water hoses going to it.
Happy Racing!
I’ll Bump You Once To Move You Over, Next Time I’ll Spin You
Old Jan 6, 2014 | 05:55 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Re: heat coming out floor vents when in off mode
That means your supposed to run away from your car because thats an indicator it might blow up.
chazman
Aug 28, 2018 03:25 PM
TheExaminer
Aug 26, 2015 04:59 PM
chazman
Aug 22, 2015 02:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
