Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)
Old Jan 2, 2014 | 05:39 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
I am thinking of buying some promaxx Patriot 185cc PN 2169 they seem to make good power and the price is not bad. Anyone have them?
http://www.jegs.com/i/ProMaxx-Perfor.../2169/10002/-1
Old Jan 15, 2014 | 10:04 PM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Re: Anyone have these heads Patriot 185cc PN 2169
I'm also considering these heads, I want to run them with a Holly Stealth Ram. I've been doing some research & I'm hearing alot of good things about them.
Search Promaxx Heads & then click on the web & images link, a bunch of info on them will come up.
Old Jan 15, 2014 | 10:14 PM
MMroc86's Avatar
Also found this thread....
Some good reviews & some bad...
https://www.thirdgen.org/forums/afte...nce-heads.html
Old Jan 15, 2014 | 10:17 PM
MMroc86's Avatar
and 3 pages worth of reviews on patriot hds.
https://www.thirdgen.org/forums/afte...iot-heads.html
Old Jan 15, 2014 | 10:20 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
i have the iron version of those heads PN 2151.
I really like them. No issues that i have not seen with any other big name head. Make good power through the entire RPM range with my XE274 cam
Old Jan 16, 2014 | 03:15 AM
Engine: forged 350
I will be buying them in about two weeks and I will be taking some good close up pics and checking them out real good.
Old Jan 16, 2014 | 09:10 AM
MMroc86's Avatar
Sounds great! Keep us posted!
Old Jan 16, 2014 | 03:03 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
After glancing through the 3 page thread that MMroc86 posted….they seem like a decent deal to me. A lot of suspicious posts by those that never tried them, but I look more at the posts of people that own them…and they all seem satisfied with them. They certainly look nice for the price!
Old Jan 16, 2014 | 03:20 PM
midias's Avatar
Here are the pics of mine
https://www.thirdgen.org/forums/tech...eads-pics.html
Old Jan 21, 2014 | 01:42 AM
blp226's Avatar
I have these heads on another type of car. THEY ARE AWESOME! I'm a die hard believer in Patriots now. I was skeptical at first but after reading some reviews I went ahead and bought them. If I had to do it all over again, I'd do the same thing.
Old Jan 21, 2014 | 07:57 AM
Copperhead's Avatar
I have the angle plug version. Work and look great but spark plug access is terrible with SLP headers. Can only get compression tester hose into about 4 holes out of 8.
Old Jan 29, 2014 | 12:35 PM
Engine: forged 350
Got my heads in today and they look great just need a little clean up of some casting lines same as big name heads.
hear are some pics just let me know if you want to see a pic of something I didn't get.
Attached Thumbnails Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)-head1.jpg   Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)-head2.jpg   Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)-head4.jpg
Old Jan 29, 2014 | 12:37 PM
Engine: forged 350
more
Attached Thumbnails Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)-head3.jpg   Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)-head5.jpg   Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)-head6.jpg
Old Jan 29, 2014 | 12:38 PM
Engine: forged 350
and the last
Attached Thumbnails Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)-head7.jpg
Old Jan 29, 2014 | 12:39 PM
Engine: forged 350
The casting lines look worse in the pics then they do in person probably because of the shadows.
Old Feb 25, 2014 | 10:48 PM
MMroc86's Avatar
How aggresive a cam can be run with these heads & still have good street manners? Looking at the flow chart it looks like they flow well to .600
Old Feb 26, 2014 | 07:58 AM
Copperhead's Avatar
Re: Anyone have these heads Patriot 185cc PN 2169 (GOT MINE PICS ADDED 1/29/14)
I have an XFI280, runs great but no full dyno test/tune yet.
Old Feb 26, 2014 | 09:27 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
This guy wasnt so lucky
Like anything else always have them checked out even the pricier brands.
http://forums.corvetteforum.com/c3-t...alve-seat.html
Old Feb 27, 2014 | 02:02 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I was going to say that the shift on the intake port from top to bottom looked terrible, like they are not aligned properly when it was casted. Not saying they are bad but it makes me wonder if other details like the tolerance between the valves and valve guides are good.
Old Jun 25, 2019 | 01:54 AM
Mike Raftis's Avatar
I do they are ok but nothing great. They are weak on power numbers on my 360. IT runs 13.30 with 2.77 gear and 3640lbs with driver. Not bad for the money but better options now in 2019.
Old Jun 25, 2019 | 11:23 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Originally Posted by Mike Raftis
I do they are ok but nothing great. They are weak on power numbers on my 355. IT runs 13.30 with 2.77 gear and 3640lbs with driver. Not bad for the money but better options now in 2019.
A bit of a necro on this post, but you don't mention what the rest of your setup is so it's hard to make a real judgement, but with a 2.77 rear gear I don't think 13.30 is half bad.
Old Jun 27, 2019 | 01:22 PM
360sbc 638 Block. Flat top with valve reliefs 9.8 to 1 comp. Isky roller 217/225@.050 .485 .505 lift 112LSA. Edelbrock RPM air gap. 750 carb. Hedman headers and Y-pipe. 3 inch exhaust. Build 700R4. 2500 stall/ lock up.1988 Iroc T-top car,UMI rear suspension setup.Cooper Zeon RSA tires,stock size. Stock looking all original and 3360 lbs without driver.
Old Jun 27, 2019 | 01:27 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
project89
Sep 24, 2015 06:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
mizz0313
Aug 12, 2015 06:45 AM
