HVAC vacuum line issue
Old Jan 17, 2014 | 06:18 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I think I screwed up....
I installed new fuel injectors yesterday in my 89 IROC, ended up changing the whole TPI base manifold since I broke a bolt off in my thermostat housing. Thankfully I had a spare. Anyway... Now I have two vacuum lines that are disconnected, I know one goes to the heater control valve thing on the passenger side. Where does the other one go? These are the lines entering the engine bay through the firewall on the passenger side.
I should have marked them, took a picture or something but I was in a hurry... like usual. Those lines were falling apart too, so I removed them when changing the intake.
But I was reading on here that one of the lines feeds vacuum pressure to the HVAC controller. Evidently its supposed to have a one way check valve and a tee, going from the intake manifold to a vacuum canister? Is that correct? I don't remember seeing a one way check valve on mine when tearing it apart. Could I just run a line from the intake to the HVAC then the other line to the heater valve? Driving to work this morning sucked with no heat... ha ha
I'll take a picture of it at break time, once the sun comes up.
Infested
May 22, 2018 11:56 PM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
