new oil pan
Old Jan 20, 2014 | 09:16 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
new oil pan
i am going to be needing a new oil pan for my engine build. it is a L98, i know any SBC pan will bolt to it, but i need to find out which ones are third gen friendly and will cooperate with our y-pipes. im not looking for a larger than stock pan, also no aluminums as i plan to lower my car more and would like the added protection of steel.
recommendations are greatly appreciated, part numbers too if you have them
Old Jan 20, 2014 | 09:19 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: new oil pan
[QUOTE=86iroct5;5701045 im not looking for a larger than stock pan, also no aluminums
recommendations are greatly appreciated, part numbers too if you have them[/QUOTE]
So just use the stock steel pan, a fresh coat of paint does wonders.
Old Jan 20, 2014 | 09:33 AM
86iroct5's Avatar
Re: new oil pan
i really want something new, i am building a whole new motor, not just rebuilding what i have. i would really prefer to buy another pan.... but that got me thinking, buy some cheapy pan that will bolt onz for storage of the old motor and just reuse the old one for the new motor, cant believe i didnt think of that before
this will prop be the route i go, but suggestions are still appreciated
Old Jan 20, 2014 | 12:02 PM
FRMULA88's Avatar
Car: 1988 Formula
Re: new oil pan
Moroso makes a steel pan (zinc plated) it has a 6 Qt. capacity.
This is the one I have in my car, and no issue with headers.
Check out their website:
http://www.moroso.com/catalog/catego...?catcode=11002
you want # 20182 ( '86 later block with 1 pc. rear main seal)
otherwise 20180 or 20181 for 2 pc rear main
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
