91 firebird runs/idles rough after big thunk, please help!
Old Jan 21, 2014 | 12:25 PM
cam444sixpak's Avatar
Car: 91' Firebird "Em"
Engine: 3.1 V6
hey, I have a 3.1 91' firebird that I got about 6 months ago with 350k miles on it. Ive been restoring it since then. it ran and drive well, except it would take a bit of turning over to start, it idled at about 1000rpm, and it would ocasionally die at stoplights. then, the other day, i put it into passing gear, and heard a loud thiunk coming from my engine bay. I quickly pulled over and made sure nothing had fallen out and it looked good, so I drove it home. on the way home, it was running REALLY rough. It would pulse really bad, and It would idle around 900 and then dip, and if i didnt give it gas It would die on me. It has a new battery, just cleaned the throttle body, not sure what else to do other than spark plugs! help!
the things that may affect it: has 10 splices in the wiring harness, but they are all done safely and correctly by a professiional. this is my daily driver so I really need to get this fixed...also the transmission is slipping and it WILL NOT go into passing gear.
Old Jan 21, 2014 | 12:42 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 91 firebird runs/idles rough after big thunk, please help!
Things to check
Oil level and color.
Compression.
Pull the valve covers and look for any damage.
Old Jan 21, 2014 | 12:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
350k on a daily driver wow
Old Jan 22, 2014 | 10:17 AM
Engine: 3.1 V6
ok, thanks.
Engine: 3.1 V6
yeah....hence the problems.
customblackbird
Aug 15, 2021 10:16 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
