Edelbrock Manifold to '88 TBI 305
Old Jan 21, 2014 | 05:02 PM
airbrushguy's Avatar
HI,
I have an '88 305 TBI roller engine from a Camaro that I would like to install in my old shop-truck.
The TBI and manifold are no longer on it and I have an older Edelbrock Performer manifold that I would like to use with a small Holley 4 barrel carb.
I know the angle of the manifold does not match the angle of the heads, so I was wondering if someone could tell me what to do to make the manifold work with this engine.
This is a very low budget build, but I would like to use this engine since it was strong when it was pulled out and is perfect for the truck.
Also...if someone knows of a cam I can use with the stock roller lifters, that would give it a nice healthy idle (not necessarily adding much HP, just a nice sound) I would appreciate a specific suggestion.
Build will probably include headers.
Old Jan 21, 2014 | 07:23 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Edelbrock Manifold to '88 TBI 305
i understand that you can ream out the center bolt holes to make it work.
Old Jan 23, 2014 | 07:53 PM
Any cam advice??
Old Jan 23, 2014 | 08:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If your sole purpose of changing out the cam is just for the sound ,
may as well save your $$ ; just take the mufflers off and just pull the choke out .
beastin91rs
Oct 9, 2015 07:38 AM
Dwayne614
Sep 28, 2015 08:33 AM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
