Total electrical failure after transmission swap
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, got bit of a problem here. Went to take a spin around the block for the first time since I've swapped in my 5 speed (from a 700r4) and everything was going great at first. However, I noticed my speedo started acting up (electronic), jumping back and forth from 0 to my speed, then the SES light came on and started flashing, and the engine simultaneously started cutting out severely to the point it just died. While the engine was dying, I noticed the voltage gauge dropped very low, dash lights were dimming, etc.
The engine totally crapped out, electronics were still working, but when I went to restart it, everything just died before I even heard the starter click. No electrical whatsoever. Thought maybe I had a battery connection issue but it was very tight. Took the negative lead off and went to put it back on but it start sparking a lot when the contacts touched so something must have shorted out. I'm so stumped! The only wiring I played with for the swap was the clutch/neutral safety, reverse lights, and had to clip (but capped off) the automatic ECM shifter reference wires. Maybe the problem is totally unrelated to the swap?
The car is a 1991 Trans Am with a 305 TPI engine by the way.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Total electrical failure after transmission swap
I'm assuming that you used swapped the automatic starter for a manual tranny starter during the conversion ?? Even if you didn't; The first thing I'd check would be the power wire connections ( fusible links ) at the starter. They often look fine,... even when they fail.
Engine: LB9
Engine: LB9
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
On my home PC I have all of them. Go to austinthirdgen.com great site. That's how I make my obd2 harnesses. Lol
Engine: LB9
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Then start putting fuses back in and see if/which ones spark... drawing power. Some, like the radio, ecm and interior lights will draw a small amount of power normally. Or, if you have a multi-meter, put it in current mode, check across the fuse contacts before putting the fuse in (the meter will flow and measure the current in place of the fuse) to see how much power each circuit is drawing. Then decide if that is normal or excessive.
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
check the wiring and fusible links at the starter and the battery cables.
my guesses are:
you have shorted wiring at the header / engine block.
or you pinched a wire between the bellhousing /engine block
Another place to check is the switched ignition power to the coil. (heavy gage pink or red wire)
I know this is a Tuned port Car but if switched ignition power to the coil is damaged and touching metal this will short out the whole ignition circuit & blow the fusible links at the starter. This happens on many TBI / Carbed cars when you change the stock air filter housing to open element because the new filter base is not recessed around the coil
A good way to check, is if the headlights still work this mean the short is on a switched ignition circuit.
my guesses are:
Engine: LB9
Hey guys, got under the car yesterday and found the probably almost instantly. Very embarrassing lol but now the car works like nothing happened.
That starter wire must've gotten caught under the crank pulley as the engine was being tilted back into position when the new transmission was installed.
Don't sweat it dude,.... The only guy that's never made a mistake is the guy that doesn't do anything !
Zip Ties FTW !!!!!
The starter wires ran behind the engine, under the pass exhaust manifold ( thru a shield bolted to the bellhousing) and to the starter in many of the 'early' thirdgens. Sometime around 86 the power distribution/starter wires were run over the pass valve cover, down the front of the engine (behind alt. ) & then back to the starter.
Glad to hear you can finally begin to ENJOY the ride while ripping thru the manual gear-box !!
Zip Ties FTW !!!!!
Engine: LB9
Zip Ties FTW !!!!!
Zip Ties FTW !!!!!
Dialed_In
Aug 20, 2015 01:45 PM
