Fuel tank capacities?
Old Jan 27, 2014 | 12:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Now, I'm not trying to start a war here. With that out of the way...
Is there a difference between the fuel tank capacity of early 82-85 carbureted and later fuel injected cars?
It seems to me almost like either the fuel pickup in my carbed sender is bent or it's too short to reach the bottom of my 87 tank. When the tank is "out of gas", I'm only putting between 10 and 12 gallons in it to fill it. The gauge is somewhere either just above or just below 1/4. With the fuel injected sender, I still had about 4 gallons in the tank at this point (as I had to pump it out and there was still a little gas in the tank when the pump wouldn't pump any more out), but with the carbed sender (external fuel pump), the engine is starving for fuel? I don't get it.
Old Jan 27, 2014 | 01:22 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Fuel tank capacities?
by my research, both carb'd and fuel injected cars have a 14 gallon tank. At least according to the replacement parts.
http://www.rickscamaros.com/camaro-r...1982-1987.html
http://www.rickscamaros.com/camaro-f...Product_Viewed
Old Jan 27, 2014 | 02:43 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
What the spec says and what you can actually squeeze into the tank are two different things.
I'd be VERY surprised if any were rated less than 14 gal, which means you can usually top it up to more than that. I've squeezed 18 gal into my '86, and it had NOT run out of fuel!
I think any less than 14 gal would be a FIRST for a production 8-cyl vehicle!
Old Mar 1, 2014 | 11:44 AM
Justinramsey's Avatar
Car: 1987 Camaro sport
Engine: 2.8l v6
Fuel pump problems ?
This is probably the wrong thread to be posting on, but I NEED help!..I recently replaced my in tank fuel pump on my 2.8l 87 Camaro sport and now if my tank is a quarter or even a bit fuller; when I go around a corner my car losses power and almost acts as though I am running out of gas. if I keep my foot on the accelerator at this point it will start jerking as im going forward. so I have to let off the gas pedal and wait about a second or two before I step on it and then it seems to be normal, well until the next corner. what im wondering is why would it be doing this with a new fuel pump. could it be something was bent when I put it back together, so that my tank is showing a quarter when its actually very low. Idk please help haha.
Old Mar 1, 2014 | 12:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In the case of adding 18 gallons, the gas station pump was likely rigged. I've had this happen to me. Fuel mileage just wasn't that good... Until I started to use another station for fuel.
RBob.
Old Mar 1, 2014 | 12:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel pump problems ?
Some of the fuel tanks don't have baffles in them. You likely got one of those. Some year along the way GM started baffling the tanks. I know that my '92 has a baffled tank, I can run it low and don't have any cutout issues.
RBob.
Old Mar 1, 2014 | 01:26 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The tank I have, which is out of my 87, does the same thing. It doesn't have any baffles in it to prevent fuel from running away from the pickup upon hard cornering (come on, who doesn't take corners a little hard? It IS an F-body, after all ). It's not your fuel system. It's the design of the tank.
I'm still looking for an answer to my original question... Is it possible that somewhere along the line my sending unit got bent? I'm still having the same issues with being completely out of gas with the gauge showing 1/4 of a tank.
Old Mar 1, 2014 | 01:40 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Just for the info stream, my 83 carb car holds about 16 gallons as per the owners guide AND what I have put in it.
Old Mar 1, 2014 | 02:01 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That's what I thought as my 87 owner's manual also says 16.5 gallons, but I wasn't entirely sure if the earlier cars were different.
I guess now I get the fun of dropping the tank .
Old Mar 1, 2014 | 02:50 PM
Engine: 2.8l v6
Hmm. I don't know why they wouldn't of thought that through and made it so that you can take corners without loosing driving capability's lol. whats weird is I never had/noticed this problem before I changed my fuel pump. which brings me back to thinking the sending unit got bent. I guess there is no way of checking. without you know CHECKING lol
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
