oil port plug size
Old Jan 31, 2014 | 05:21 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
oil port plug size
I have a pre 86 350 in my 91 rs. I am wanting to move my oil pressure switch/sender from above the oil filter to the port by the distributor. Will the oil plug by the distributor fit in the hole by the filter?
Also, the plug by the distributor needs a square socket. Anyone know what size it is?
Old Jan 31, 2014 | 06:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: oil port plug size
Iirc 1/8 npt
Old Jan 31, 2014 | 07:18 PM
No; that one is ¼" pipe IIRC.
Crescent wrench. (make sure it's not a metric one )
Old Jan 31, 2014 | 07:44 PM
So they are both 1/4 then?
Old Jan 31, 2014 | 08:13 PM
1/8 npt
Not sure....
Can I give you my 1/8 of a dollar in exchange for your ¼ of a dollar? maybe even, a coupla thousand times?
I thought so.
Old Jan 31, 2014 | 08:17 PM
Twin_Turbo's Avatar
The one on the rear chna wall is indeed 1/8, the one above the filter 1/4.
Old Jan 31, 2014 | 08:40 PM
OK so the sensor by the filter won't fit in the port by the China wall?
Old Jan 31, 2014 | 09:11 PM
Engine: Lb9
Transmission: M20
The sensor won't fit the china walk without a T .
Old Jan 31, 2014 | 09:28 PM
the reason i am asking this is because it is a pain in the butt to tighten. i figure if i moved it to the top it would be easier.
that or i was reading on here a little bit. would i be able to just completely remove the sensor and still have the stock fuel pump work?
Old Jan 31, 2014 | 10:22 PM
Engine: Lb9
Transmission: M20
Doesn't sound like your using the correct sender socket, plenty of room above the oil filter not so much behind the intake.
http://www.autozone.com/autozone/acc...ntifier=141490
Old Jan 31, 2014 | 10:29 PM
that only goes to 1 and 1/16. the "nut" part on mine is 1 and 3/16
Old Jan 31, 2014 | 10:35 PM
Engine: Lb9
Transmission: M20
I just grabbed a acdelco 25036940 out of my garage. Its fits the 1 1/16
Old Jan 31, 2014 | 11:27 PM
thats not the same sensor as i have. mine is a lot longer.
mine looks similar to this, but mine doesnt have any black on it.
http://www.autozone.com/autozone/par...4_113137_8450_
Old Feb 1, 2014 | 12:53 AM
ok so here are a couple pics of what i have.
what the sensor looks like....
here is a close up of the threads, i am not able to turn it anymore. does it look like it is all the way in? it seems to be hitting the lip above the filter....
Old Feb 1, 2014 | 12:56 AM
Engine: Lb9
Transmission: M20
Its a pipe thread, a tapered thread. Remove it put some liquid Teflon or Rtv on the threads and tighten it down. It is hitting the block, you might need to goto the hardware store buy a short 1/4 npt straight piece and a 1/4 female street fitting.
Old Feb 1, 2014 | 12:59 AM
ok cool. last time it ran ( 4 years ago) it dripped oil out of there. i managed to get 1/4 turn out of it the other day and played with it more today. i couldnt get it to turn anymore. so hopefully it wont leak anymore
Old Feb 1, 2014 | 01:02 AM
Engine: Lb9
Transmission: M20
If not making a piece to extend it out 2 inches will fix it and be under $10
Old Feb 1, 2014 | 01:06 AM
i will keep that in mind. thanks
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Navy8125
Aug 21, 2015 09:32 AM
knight72
Aug 10, 2015 09:32 PM
mx127
Aug 10, 2015 08:13 AM
