Next step with my car.
Old Feb 1, 2014 | 11:17 AM
Buddy Norwood's Avatar
Ok, i had a earlier post about stroking my 305 but that ended up going way off subject. So, I'v come down to two options. Cost wise it will be almost the same with either upgrde but id like some of your guys opinions what id benefit more from with my set up. My car, 89 305, 650 dp carb, performer intake, stock tbi heads that have been milled .010 and i put hogged them to 1.94 valve. Comp cam .510/.520 lift, 232/236 duration @ .050. 3200 stall converter, 3.73's, 100 shot of NOS at the track. Stock lower end (with all new bearings)
Cars in paint shop right now but when i pull it out im going to either stroke it and run 5cc dish pistons to bump compression or throw on a set of trick flow 23 heads with rpm air gap intake. Budgets really only allowing one or the other. With what i have already done, what do you guy think would be the best bang for the buck?
Oh and btw, i AM keeping 305 =) thanks.
Old Feb 1, 2014 | 11:45 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Next step with my car.
There's literally tons of past posts about 334 strokers on this site…here's an active one now:
https://www.thirdgen.org/forums/engi...4-stroker.html
So I guess heads and intake…you could swap those onto something else in the future at least….
Old Feb 2, 2014 | 11:47 AM
would the trick flows be a big hp gain over stock?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Linson
Sep 21, 2015 01:08 PM
scottmoyer
Sep 7, 2015 07:06 PM
Strick1
Sep 4, 2015 07:11 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
