injector seating
Old Feb 9, 2014 | 09:59 PM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
injector seating
im trying to put my engine back together but im not to sure about the injectors. I wiggled them in as far as I felt comfortable with but I don't want to break anything. are they supposed to be sitting flush on the manifold or is this how they are supposed to be? sorry for the large image I figured it would be easiest to see what im talking about. thanks in advance
Old Feb 9, 2014 | 11:16 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: injector seating
When I replaced mine recently I was instructed to use dish soap on the o-rings and seat them with back and forth rocking motion instead of a twisting motion. I seated them in the rail first, positioned the rail and then pressed them flush with the manifold after they were all in place. Good luck.
Old Feb 10, 2014 | 04:13 AM
Car: camaro
Engine: 3.1
Transmission: auto
that's pretty much what I did. except I used Vaseline but its not sitting flush. ill probly try again and see if I get better results
Old Feb 10, 2014 | 07:14 AM
Looks fine, about like they usually do...
Basically as long as the O-rings went in completely, it's all good.
Old Feb 10, 2014 | 03:08 PM
Car: camaro
Engine: 3.1
Transmission: auto
I put brand new O rings on I should've looked at them before I pulled them to see how they were seated. I just to put it all back together just to find out fuel is leaking out.
Old Feb 10, 2014 | 05:42 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
I used motor oil, push in till they stop. I put in engine first per instructions, then wiggled the rail onto the injectors. I had one oring get pinched in the rail, when I fixed and reset I used a lot of oil to lube it. No leaks after that.
Strongly advise you to do a test before you reassemble plenum and runners.
Old Feb 11, 2014 | 03:20 AM
Car: camaro
Engine: 3.1
Transmission: auto
I put it all back together already. I didn't get it to much better than the pics but I didn't see any leaks or anything ran the car for about 20-30 mins afterwards
Old Feb 12, 2014 | 06:49 PM
Car: 90 Iroc Vert
Engine: 5.0L
You should be good then, I always have to do it twice ... LOL.
Once I bolted the rail on and hooked up fuel lines, hooked up batt and energized the fuel pump. Quik test.
I did have the Schrader valve go bad on the rail after the swap. Easy fix the extra large valves can get at autoparts store - they have universal AC tuneup kit that worked. Keep an eye on it.
Old Feb 13, 2014 | 03:27 AM
Car: camaro
Engine: 3.1
Transmission: auto
definitely keeping an eye on it for a while. ive never torn into an engine as far as I did. so im always wondering if I did it right or not. took it out for a drive today everything still looks good
Street Lethal
Apr 30, 2019 12:14 PM
92projectcamaro
Jan 18, 2016 08:00 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
z28_AJ
Aug 27, 2015 08:59 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
