i feel pretty dumb right now
Old 02-19-2014, 12:47 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
but can someone help me out, rebuilding most of my dist and got a new ign control module, and now i don't know what wires go where. what two wires hook to the other end of the module? if anyone has a picture thatd be great
Old 02-19-2014, 12:56 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: i feel pretty dumb right now
I believe the connector that comes from the pickup coil attaches to the ignition control module.
Old 02-19-2014, 01:50 PM
kmcn47's Avatar
Transmission: 5spd
the seven pin side is fine, the other side is the one that im having trouble with. there is a spade connector on what looks like a condenser (im guessing the radio noise canceller) that im not sure where it goes. if it does go on one of the the two terminals on that side of the module then what goes on the other one?
Old 02-19-2014, 03:14 PM
kmcn47's Avatar
Transmission: 5spd
some pics to help. the first is of my capless distributor.
in here you can see the litte condenser thingy that has the blue wire with a terminal on the end. no idea where this goes
you can also see the black wire form the three pin "set the timing" plug that goes into the distributor cap. i attatched it to the screw that holds the little condenser thing to the distributo because it had a ring terminal and some black wire (broken) on it when i got the cap off, i assumed (i know i know) that this is where it goes. i also put blade terminals on the red wire coming off the three pin plug the brown wire also on that plug already had one, i also don't know where these go
if i need that plastic cover that used to go over all of these wires
if re attaching the black wire there was right
where the hell does that little blue wire go?
Old 02-19-2014, 03:15 PM
kmcn47's Avatar
Transmission: 5spd
second picture of the three wire connector that goes on the cap
Old 02-19-2014, 03:20 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Best picture I have
Old 02-19-2014, 03:24 PM
kmcn47's Avatar
Transmission: 5spd
it appears i am missing some parts. but thank you!!!!!!!! atleast with that picture i can probably make it work the way its supposed to just knowing where everything is supposed to go
Old 02-19-2014, 03:32 PM
kmcn47's Avatar
Transmission: 5spd
actually i feel really dumb now, pretty sure i just saw this last night
http://www.rockauto.com/catalog/more...284&cc=1035492
Hotrodboba400
12-10-2019 07:07 PM
83 Crossfire TA
01-03-2016 01:26 PM
NastyEngines
Group Purchases
09-08-2015 10:14 AM
TheExaminer
09-06-2015 11:40 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: i feel pretty dumb right now
