Changed cap and rotor now car wont start.
Car: 1984 camaro
Engine: 305 carbed
Axle/Gears: not sure
So i had bought cap, rotor, plugs, and wires. i started with the cap,and rotor. moved plugs over to new cap first, then removed old cap and rotor. installed new rotor (i spun it slightly accidentally moved it back), took old coil off old cap, sanded down rusty ground, moved coil over to new cap, tightened the cap down, and plugged in wires to coil. decided to try to fire it up before i moved on to plugs and wires. low and behold now my car wont start it just turns and turns and turns... killed my batt...
any insight on this would be greatly appreciated. thanks
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: Changed cap and rotor now car wont start.
did you plug the power wire to the cap back up?
Car: 1984 camaro
Engine: 305 carbed
nvm i got it figured... dizzy is lose i knocked it out of timing. got it fired up and warming up to time now.
1992 Trans Am
05-10-2023 07:19 PM
