Won't Spin or start
Old Mar 4, 2014 | 04:12 PM
free1180's Avatar
Car: 1989 5.7 IROC all original
Engine: 350 TPI Stock but clean
Transmission: auto of course
Axle/Gears: Posi Limited Slip stock
Won't Spin or start
I have a 1989 Camaro IROC, 5.7 mostly stock. Never had a problem before. Has a MSD 6a box with the harness, and aftermarket alarm.
Cruised 300 miles the day before not even a hint. Went by a friends house took a short drive and went to leave and the car does not even click. All the gauges cycle and all electrical item work, lights, horn, including the alarm will cycle.
turn the key and nothing except the gauges cycle. the car is not in a good place to get work done.
checked fuses, changed to the spare key (I have those key with the little thing on them) I'm at a loss. Like I said it has never acted up before.
also can anybody recommend a good shop in New Orleans area. I have some things I would like to get done once I get her running again.
thanks,
Old Mar 4, 2014 | 04:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Won't Spin or start
Do a search ; lots of recent starter problem threads.( is a electrical problem , check in the electronics section )
1st step is to hot wire the starter and confirm it actually works
If it does then you have a problem somewhere with the control wiring between Ign switch and the starter
Need to check for voltage at all points on that circuit when key in START position
See
http://92b4crs.tripod.com/86wiring/dia-pics/30-2.jpg
Old Mar 4, 2014 | 04:50 PM
free1180's Avatar
thanks for the diagram link and the help I'm searching
Old Mar 4, 2014 | 04:56 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
I hsd the same problem sunday leaving a car show I unhooked the battery hooked it back up and it started worth a shot worked for me
Old Mar 4, 2014 | 05:07 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Sorry , miss read your year.
IIRC You have VATS?
www.thirdgen.org/vats_passkey_system
Search the 1001 VATS posts.
If the key pellet is worn or dirty , or same for the contacts in the Ign switch that read that pellet ,the VATS module will not be able to read the key correctly and wil prevent the starter from operating
Old Mar 4, 2014 | 05:15 PM
free1180's Avatar
tried that no luck but thanks
Old Mar 4, 2014 | 06:13 PM
free1180's Avatar
Yeah I had read some things over the years about the VATS and I have a couple of extra ignition keys, so I tried them and had no luck. It sure seems like that is the trouble but I also heard that there may be a fused line (purple wire) that has a slow blow fuse. Not sure if that is true on an 89 but he told me he had a El Camino 85 I think and this happened to him twice while he owned it. I really appreciate you coming back to me on this. Unfortunately it will have to wait till the weekend.
Old Mar 4, 2014 | 07:12 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Bypass ( jumper ) the starter enable relay operated by VATS and see if it cranks over?
If it fires up ,the relay is the problem ; if it only cranks over you have other VATS problems like the key not being read or a faulty VATS module
Disconnect the plug on the VATS wiring under the column and put your DVM on the wires up the column to the key.
With key in Ign see if you get a resistance reading
Old Mar 4, 2014 | 07:26 PM
free1180's Avatar
thanks so much for all the help I think I have quite a days work coming at me but at least I wont be chasing my tail. I really appreciate all the help
Old Mar 6, 2014 | 09:48 PM
free1180's Avatar
@ VetteOZ
I want to thank you for the recommendations and the advice, it was a VATS issue and it turned out to be the wire connected to the key cylinder so we're searching for the parts. I really appreciate it. a few more hours and she'll be cruising again.
thanks again
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 19, 2015 12:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
