305 TPI won't start when hot.
Old Mar 15, 2014 | 07:41 AM
Tri458's Avatar
1986 305 tpi transplant in a 58 Apache. 700r4 trans.
01227165 AMU ECM
Had trouble when first installed with stalling after about 10 minutes.
Installed new pickup coil, new ICM, new coil and pressure regulator and she now starts on the button and runs forever without cutting out.
However.... She will not re- start once up to temperature, unless it's left for about an hour to cool.
Good spark on the plugs.
12 v on the injectors and 15 Ohms.
12v on ECM connector terminals D15 and D16 (injector returns to ECM)
Terminal B5 on the ECM connector shows 0.13 volts with ignition on and increases to 1.2 volts when cranking.
Tried disconnecting one at a time the coolant temp sensor, TPS and cold start injector but still no start.
Fuel pressure 42psi constant.
Only thing left is ECM or PROM? Unless I am missing something silly?
Checked all wiring and no obvious faults/ shorts.
DOES ANTONE HAVE A MAGIC WANT... PLEASE HELP!
Old Mar 15, 2014 | 08:40 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: 305 TPI won't start when hot.
Will it fire if you prime it with carb cleaner or something?
Old Mar 15, 2014 | 09:07 AM
Tri458's Avatar
Haven't tried it but seems no fuel getting to the plugs. Not at home till tomorrow so will try and let you know the outcome.
Old Mar 16, 2014 | 02:11 PM
Tri458's Avatar
Hi there Mjdavis68
Run her up to temperature and turned her off with the key. Would not fire at all when I tried to start.
Gave a squirt of starter fluid down the plenum and she fired 5 or 6 times then started.
Did the same again and exactly the same.. Would not start. Squirt of starter, fired 5 or 6 times then started.
Any ideas please?
Old Mar 16, 2014 | 07:58 PM
ex-x-fire's Avatar
Did you ohm the injectors when hot?
Old Mar 16, 2014 | 08:09 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
i had the same issue on my 91Z28 vert last year (only 7K miles on it!) i had 3-4 bad injectors when it was hot...
replaced all the injectors and it runs again like new
Old Mar 16, 2014 | 09:27 PM
southbay08's Avatar
The stock injectors are extremely prone to coil failure. More often than not they fail when they are hot.
Old Mar 17, 2014 | 05:30 PM
Tri458's Avatar
All 8 injectors are 15 Ohm when hot and when cold, but the 9th cold start injector shows only 3 Ohm
Is this correct?
Old Mar 19, 2014 | 11:18 AM
Tri458's Avatar
Tried the dizzy out of my 89 Corvette on the engine today and same problem, so can dismiss issues with the distributor from now.
All wiring to and from the distributor looks fine.
Checked all voltages back to the ECM and everything is as it should be except terminals b1 and c16 are only showing 12 volts when the engine is running. Thought they should both be 12 volts with the key in the on position?
Could this be the issue?
Someone please help.. I am now tearing my hair out... What's left of it!
Old Mar 20, 2014 | 06:58 PM
Tri458's Avatar
Have done a voltage test on pins 15and 16 with the injectors unplugged and it shows a nil reading so nothing shorted to live, so have come to the conclusion the ECM is at fault. Have bought another so will have it in about 2 weeks...
Thanks to you all for your input. I will let you know if it works!
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
