new motor,cam,etc. timing help needed
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok i just built my 355 sbc with the 268xe comp cam. they state that 10-12 base timing and total of 34 by 3000 rpm. how do i limit it to the 34*? last motor i had i couldnt get the total under 42* killing performance and fuel mileage. im using same unit so id rather nick it in the butt now then later. any help? im using an aftermarket billet hei unit WITHOUT vaccum advance. thanks!!
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Re: new motor,cam,etc. timing help needed
It should come with different size bushings to limit travel.
Engine: 355
i have this distributor. didnt come with bushings. http://www.ebay.com/itm/SBC-BBC-CHEVY-350-383-SUPER-65K-HEI-DISTRIBUTOR-6500-R-/331066061910?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d15133456&vxp=mtr#ht_8279wt_1364
Car: 1988 gta
Engine: 383
Just read your link, doesn't mention a manufacturer, doesn't show a pic of the weights and springs. Call his tech line. All the ones I've dealt with have bushings that limit the advance weight travel. What ignition system are you running?
Engine: 355
i have the msd 6 al ignition box
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Yep Skip White. Lol. Definitely Procomp.
Engine: 355
yes its procomp. its setup like a normal distributor. i believe it has weights and springs.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You will need something like this
http://www.summitracing.com/parts/su...Fe1QOgodNRQARg
Why did you go without vac advance?
Car: 1988 gta
Engine: 383
I think those are for non HEI MSD distributors only
Car: 1988 gta
Engine: 383
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Buy an MSD Dist. now, those dist are junk, you will keep having issues until it is replaced. imo
Engine: 355
Engine: 355
It is hard to limit the advance on cheap HEI distributors.
http://www.camaros.net/forums/showthread.php?t=119691
Otherwise you reduce initial timing but add lighter springs so at idle the weights move more
If you want full adjust ability you need a MSD system.
Change the springs and see how it works it will be some trial and error.
Engine: 355
Engine: 355
