Accelerates Out of Control
Old Apr 1, 2014 | 01:17 AM
JBeanie's Avatar
Car: 89 IROC-Z
Axle/Gears: 9 Bolt Borg-Warner/3.27
I've had 2 Camaros do this to me so far. One being a 91 RS V6 and the other a 89 IROC-Z 350 TPI.
Each time I'm stopped and then as I accelerate the car keeps accelerating by it's self to the point where I have to turn the ignition off to stop it. After letting the car sit for a few minutes then starting it back up it runs fine. My IROC-Z has done it twice now and the RS only one time. Every time this has happened its been summer time and hot outside.
I was thinking maybe the cruise control? But then the CC on my IROC-Z was working then.
Anyone have this problem before? If so, what was causing it?
Any help would be greatly appreciated, Thanks!
Old Apr 1, 2014 | 06:13 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Accelerates Out of Control
Some thing to check: Sticky throttle plate, defective TPS, interference on throttle linkage, bent cable, vacuum leak.
Old Apr 2, 2014 | 06:59 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
I would put a stronger throttle return spring on it.
Old Apr 9, 2014 | 09:10 PM
JBeanie's Avatar
Car: 89 IROC-Z
Thanks for the info guys.
Old Apr 9, 2014 | 09:27 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I've heard of floor mats doing the same, especially when random.
Old Apr 10, 2014 | 01:05 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If the TB is worn , the engine vac will pull on the butterflies when the throttle is released and will jam them against the bore in a open position.
As soon as you kill the engine , there is no vac so the butterflies close properly
Typically tapping the pedal when it occurs will close them
Old Apr 24, 2014 | 10:02 PM
JBeanie's Avatar
Car: 89 IROC-Z
If it ever happens again I'll give it a try. Thanks!
Old Apr 24, 2014 | 10:42 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
I had a similar problem with a BBK 52MM, I added two stronger throttle return springs and its been better since.
Old Apr 25, 2014 | 12:21 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
I had my accelerator stay stuck at WOT going down the road and that scared the crap out of me. I turned it off, coast it to a safe place and it was the TVS cable somehow interfered. I dont remember exactly but the part it slides in the clip area got stuck. I was able to later adjust it.
Racerx974
Sep 19, 2015 10:16 AM
amcnellis
Sep 16, 2015 04:16 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
